mysql-k8s
Charmed MySQL K8s
8.0/stable 211 06 Jan 2025
8.0/stable 210 06 Jan 2025
8.0/candidate 211 11 Dec 2024
8.0/candidate 210 11 Dec 2024
8.0/beta 211 09 Dec 2024
8.0/beta 210 09 Dec 2024
8.0/edge 222 27 Jan 2025
8.0/edge 221 27 Jan 2025
System requirements
The following are the minimum software and hardware requirements to run Charmed MySQL on Kubernetes.
Software
  • Ubuntu 22.04 (Jammy) or later
  • Kubernetes 1.27+
  • Canonical MicroK8s 1.27+ (snap channel 1.27-strict/stable and newer)
Juju
The charm supports several Juju releases from 2.9 LTS onwards. The table below shows which minor versions of each major Juju release are supported by the stable Charmhub releases of MySQL K8s.
Juju major release Supported minor versions Compatible charm revisions Comment
3.6 LTS 3.6.1+ 213+
3.5 3.5.2+ 153+
3.4 3.4.3+ 153+ Known issues with 3.4.2: bug #1, bug #2
3.1 3.1.6+ 99+
2.9 LTS 2.9.32+ 75 +
MySQL Group Replication requirements
  • In order to integrate with this charm, every table created by the integrated application must have a primary key. This is required by the group replication plugin enabled in this charm.
  • The count of Charmed MySQL K8s units in a single Juju application is limited to 9. Unit 10+ will start; however, they will not join the cluster but sleep in a hot-swap reserve.
Hardware
Make sure your machine meets the following requirements:
  • 8GB of RAM.
  • 2 CPU threads.
  • At least 20GB of available storage.
The charm is based on the charmed-mysql ROCK OCI, which is recursively based on the charmed-mysql snap. It currently supports:
  • amd64
  • arm64 (from revision 180+)
Contact us if you are interested in a new architecture!
Networking
  • Access to the internet for downloading the required OCI/ROCKs and charms.
  • Only IPv4 is supported at the moment
