Charmed MySQL K8s
8.0/stable 180 02 Sep 2024
8.0/stable 181 02 Sep 2024
8.0/candidate 180 26 Aug 2024
8.0/candidate 181 26 Aug 2024
8.0/beta 207 15 Nov 2024
8.0/beta 206 15 Nov 2024
8.0/edge 209 18 Nov 2024
8.0/edge 208 18 Nov 2024
System requirements
The following are the minimum software and hardware requirements to run Charmed MySQL on Kubernetes.
Software
  • Ubuntu 22.04 (Jammy) or later
  • Kubernetes 1.27+
  • Canonical MicroK8s 1.27+ (snap channel 1.27-strict/stable and newer)
Juju
The charm supports several Juju releases from 2.9 LTS onwards. The table below shows which minor versions of each major Juju release are supported by the stable Charmhub releases of MySQL K8s.
Juju major release Supported minor versions Compatible charm revisions Comment
3.5 3.5.2+ 153+
3.4 3.4.3+ 153+ Known issues with 3.4.2: bug #1, bug #2
3.1 3.1.6+ 99+
2.9 LTS 2.9.32+ 75 +
MySQL Group Replication requirements
  • In order to integrate with this charm, every table created by the integrated application must have a primary key. This is required by the group replication plugin enabled in this charm.
  • The count of Charmed MySQL K8s units in a single Juju application is limited to 9. Unit 10+ will start; however, they will not join the cluster but sleep in a hot-swap reserve.
Hardware
Make sure your machine meets the following requirements:
  • 8GB of RAM.
  • 2 CPU threads.
  • At least 20GB of available storage.
The charm is based on the charmed-mysql ROCK OCI, which is recursively based on the charmed-mysql snap. It currently supports:
  • amd64
  • arm64 (from revision 180+)
Contact us if you are interested in a new architecture!
Networking
  • Access to the internet for downloading the required OCI/ROCKs and charms.
  • Only IPv4 is supported at the moment
