mysql-k8s
Charmed MySQL K8s
8.0/stable 240 11 Mar 2025
8.0/stable 241 11 Mar 2025
8.0/candidate 240 27 Feb 2025
8.0/candidate 241 27 Feb 2025
8.0/beta 240 25 Feb 2025
8.0/beta 241 25 Feb 2025
8.0/edge 249 26 Mar 2025
8.0/edge 248 26 Mar 2025
Release Notes
This page provides high-level overviews of the dependencies and features that are supported by each revision in every stable release.
To learn more about the different release tracks and channels, see the Juju documentation about channels.
To see all releases and commits, check the Charmed MySQL K8s Releases page on GitHub.
Release MySQL version Juju version TLS encryption* COS monitoring Minor version upgrades Cross-regional async replication
240, 241 8.0.41 3.5.4+ check check check check
210, 211 8.0.39 3.5.4+ check check check check
180, 181 8.0.37 3.4.3+ check check check check
153 8.0.36 3.4.3+ check check check check
127 8.0.35 3.1.6+ check check
113 8.0.34 3.1.6+ check check
99 8.0.34 3.1.6+ check check
75 8.0.32 2.9.32+ check check
* TLS encryption: Support for v2 or higher of the tls-certificates interface. This means that you can integrate with modern TLS charms.
For more details about a particular revision, refer to its dedicated Release Notes page. For more details about each feature/interface, refer to the documentation linked in the column headers.
Architecture and base
Several revisions are released simultaneously for different bases/series using the same charm code. In other words, one release contains multiple revisions.
If you do not specify a revision on deploy time, Juju will automatically choose the revision that matches your base and architecture.
See: juju set-constraints, juju info
Release 210-211
Revision amd64 arm64 Ubuntu 22.04 LTS
240 check check
241 check check
Older releases
210 check check
211 check check
Release 180-181
180 check check
181 check check
Release 153
153 check check
Release 127
127 check check
Release 113
113 check check
Release 99
99 check check
Release 75
75 check check
