mysql-k8s
Charmed MySQL K8s
8.0/stable 240 11 Mar 2025
8.0/stable 241 11 Mar 2025
8.0/candidate 240 27 Feb 2025
8.0/candidate 241 27 Feb 2025
8.0/beta 240 25 Feb 2025
8.0/beta 241 25 Feb 2025
8.0/edge 249 26 Mar 2025
8.0/edge 248 26 Mar 2025
Profiles
Charmed MySQL K8s resource utilization depends on the chosen profile:
juju deploy mysql-k8s --trust --config profile=testing
Profile values
Value Description Tech details
production
(default)
Maximum performance ~75% of ‘Allocatable memory’ granted for MySQL
max_connections=RAM/12MiB (max safe value)
testing Minimal resource usage innodb_buffer_pool_size = 20MB
innodb_buffer_pool_chunk_size=1MB
group_replication_message_cache_size=128MB
max_connections=100
performance-schema-instrument=‘memory/%=OFF’
Config change
Note: Pre-deployed application profile change is planned but currently is NOT supported.
To change the profile, use juju config (see all charm configs):
juju deploy mysql-k8s --trust --config profile=testing && \
juju config mysql-k8s profile=production
Juju Constraints
Juju constraints allows RAM/CPU limits for Kubernetes pods:
juju deploy mysql-k8s --trust --constraints cores=8 mem=16G
Juju constraints can be used together with charm profile:
juju deploy mysql-k8s --trust --constraints cores=8 mem=16G --config profile=testing
