Charmed MySQL K8s
- Canonical
8.0/stable | 180 | 02 Sep 2024 | |
8.0/stable | 181 | 02 Sep 2024 | |
8.0/candidate | 180 | 26 Aug 2024 | |
8.0/candidate | 181 | 26 Aug 2024 | |
8.0/beta | 203 | 07 Oct 2024 | |
8.0/beta | 202 | 07 Oct 2024 | |
8.0/edge | 207 | 09 Oct 2024 | |
8.0/edge | 206 | 09 Oct 2024 |
Alert rules
This page contains a markdown version of the alert rules described in the mysql-k8s-operator
repository. The following file(s) are the source of truth:
This documentation describes the latest alert rule expressions. See the YAML file(s) on listed above if you require an older version.
MySQLExporterK8s
Alert | Severity | Notes |
MySQLDown | MySQL instance is down. |
MySQLTooManyConnections(>90%) | MySQL instance is using > 90% of max_connections .Consider checking the client application responsible for generating those additional connections. |
MySQLHighThreadsRunning | MySQL instance is actively using > 80% of max_connections .Consider reviewing the value of the max-connections config parameter or allocate more resources to your database server. |
MySQLHighPreparedStatementsUtilization(>80%) | MySQL instance is using > 80% of max_prepared_stmt_count .Too many prepared statements might consume a lot of memory. |
MySQLSlowQueries | MySQL instance has a slow query. Consider optimizing the query by reviewing its execution plan, then rewrite the query and add any relevant indexes. |
MySQLInnoDBLogWaits | MySQL instance has long InnoDB log waits. MySQL InnoDB log writes might be stalling. Check I/O activity on your nodes to find the responsible process or query. Consider using iotop and the performance_schema. |
MySQLRestarted | MySQL instance restarted. MySQL restarted less than one minute ago. If the restart was unplanned or frequent, check Loki logs (e.g. error.log ). |
