Charmed MySQL K8s
- Canonical
8.0/stable | 240 | 11 Mar 2025 | |
8.0/stable | 241 | 11 Mar 2025 | |
8.0/candidate | 240 | 27 Feb 2025 | |
8.0/candidate | 241 | 27 Feb 2025 | |
8.0/beta | 240 | 25 Feb 2025 | |
8.0/beta | 241 | 25 Feb 2025 | |
8.0/edge | 249 | 26 Mar 2025 | |
8.0/edge | 248 | 26 Mar 2025 |
Upgrade Juju for a new database revision
This guide contains instructions to perform a patch or major/minor Juju upgrade to a controller and model containing a database charm.
For more background about Juju upgrades in the context of database charms, check Explanation > Juju > Juju upgrades.
Patch version upgrade
A PATCH Juju upgrade (e.g. Juju3.1.5
→ 3.1.8
) can be easily applied in-place.
sudo snap refresh juju
juju upgrade-controller
# wait until complete
juju upgrade-model
Once the model has finished upgrading, you can proceed with the charm upgrade.
Major/minor version upgrade
The easiest way to perform a MAJOR/MINOR Juju version upgrade (e.g. Juju3.1.8
→ 3.5.1
), is to update the controller and model to the new version, then migrate the model.
Commands summary
The following is a summary of commands that upgrade Juju to3.5/stable
sudo snap refresh juju --channel 3.5/stable
juju bootstrap lxd lxd_3.5.1 # --agent-version 3.5.1
juju migrate lxd_3.1.8:mydatabase lxd_3.5.1
juju upgrade-model -m lxd_3.5.1:mydatabase
Example
This section goes over the commands listed in the summary above with more details and sample outputs.In this example scenario, we have mysql
deployed in model mydatabase
on the Juju controller lxd_3.1.8
~$ juju status
mydatabase lxd_3.1.8 localhost/localhost 3.1.8 unsupported 22:54:48+02:00
mysql 8.0.34-0ubun... active 3 mysql 8.0/stable 196 no
mysql/0* active idle 0 10.217.68.104 3306,33060/tcp Primary
mysql/1 active idle 1 10.217.68.118 3306,33060/tcp
mysql/2 active idle 2 10.217.68.144 3306,33060/tcp
0 started 10.217.68.104 juju-a4598a-0 ubuntu@22.04 Running
1 started 10.217.68.118 juju-a4598a-1 ubuntu@22.04 Running
2 started 10.217.68.144 juju-a4598a-2 ubuntu@22.04 Running
To upgrade Juju to v.3.5.1
, we go through the following steps:
1. Update the Juju CLI
~$ juju --version
3.1.8-genericlinux-amd64
~$ sudo snap refresh juju --channel 3.5/stable
~$ juju --version
3.5.1-genericlinux-amd64
2. Bootstrap the new controller
~$ juju bootstrap lxd lxd_3.5.1 # --agent-version 3.5.1
Creating Juju controller "lxd_3.5.1" on lxd/localhost
Looking for packaged Juju agent version 3.5.1 for amd64
Located Juju agent version 3.5.1-ubuntu-amd64 at https://streams.canonical.com/juju/tools/agent/3.5.1/juju-3.5.1-linux-amd64.tgz
To configure your system to better support LXD containers, please see: https://documentation.ubuntu.com/lxd/en/latest/explanation/performance_tuning/
Launching controller instance(s) on localhost/localhost...
- juju-374723-0 (arch=amd64)
Installing Juju agent on bootstrap instance
Waiting for address
Attempting to connect to 10.217.68.44:22
Connected to 10.217.68.44
Running machine configuration script...
Bootstrap agent now started
Contacting Juju controller at 10.217.68.44 to verify accessibility...
Bootstrap complete, controller "lxd_3.5.1" is now available
Controller machines are in the "controller" model
3. Migrate the entire model mydatabase
to the new controller (no database outage here)
~$ juju controllers
Controller Model User Access Cloud/Region Models Nodes HA Version
lxd_3.1.8* mydatabase admin superuser localhost/localhost 2 1 none 3.1.8
lxd_3.5.1 - admin superuser localhost/localhost 1 1 none 3.5.1
~$ juju models -c lxd_3.1.8
Controller: lxd_3.1.8
Model Cloud/Region Type Status Machines Units Access Last connection
controller localhost/localhost lxd available 1 1 admin just now
mydatabase* localhost/localhost lxd available 3 3 admin 36 seconds ago
~$ juju models -c lxd_3.5.1
Controller: lxd_3.5.1
~$ juju migrate lxd_3.1.8:mydatabase lxd_3.5.1
Migration started with ID "5f227519-3cdb-4538-871c-1c4589a4598a:0"
4. Use juju models
to check the migration process has started ( model status=busy
). At the end of the process, the model is no longer available on the old controller as it has been moved to new controller
~$ juju models --controller lxd_3.1.8
mydatabase* localhost/localhost lxd busy 3 3 admin 1 minute ago
~$ juju models --controller lxd_3.5.1
mydatabase localhost/localhost lxd available 3 3 admin 1 minute ago
5. Upgrade the model version itself (no database outage here)
> juju status -m lxd_3.5.1:mydatabase
mydatabase lxd_3.5.1 localhost/localhost 3.1.8 unsupported 22:58:10+02:00
best version:
3.5.1
started upgrade to 3.5.1
mydatabase lxd_3.5.1 localhost/localhost 3.5.1 unsupported 22:59:01+02:00
At this stage, the application continues running under the supervision of the new controller version and is ready to be refreshed to the new charm revision.
You can now proceed with the charm upgrade.
Resources
Further documentation about Juju upgrades:- MySQL K8s | Explanation > Juju > Juju upgrades
- Juju | Upgrade a controller
- Juju |
upgrade-controller
- Juju |
upgrade-model
