Charmed MySQL K8s
- Canonical
8.0/stable | 240 | 11 Mar 2025 | |
8.0/stable | 241 | 11 Mar 2025 | |
8.0/candidate | 240 | 27 Feb 2025 | |
8.0/candidate | 241 | 27 Feb 2025 | |
8.0/beta | 240 | 25 Feb 2025 | |
8.0/beta | 241 | 25 Feb 2025 | |
8.0/edge | 249 | 26 Mar 2025 | |
8.0/edge | 248 | 26 Mar 2025 |
Perform a minor rollback
Example: MySQL 8.0.34 → MySQL 8.0.33
(including charm revision bump: e.g Revision 43 → Revision 42)
After a juju refresh
, if there are any version incompatibilities in charm revisions, its dependencies, or any other unexpected failure in the upgrade process, the process will be halted and enter a failure state.
Even if the underlying MySQL cluster continue to work, it’s important to roll back the charm to a previous revision so that an update can be attempted after further inspection of the failure.
Warning: Do NOT trigger rollback
during the running upgrade
action! It may cause an unpredictable MySQL cluster state!
Summary of the rollback steps
- Prepare the Charmed MySQL K8s application for the in-place rollback.
- Rollback. Perform the first charm rollback on the first unit only. The unit with the maximal ordinal will be chosen.
- Resume. Continue rolling back the rest of the units if the first unit rolled back successfully.
- Check. Make sure the charm and cluster are in healthy state again.
Step 1: Prepare
To execute a rollback, we use a similar procedure to the upgrade. The difference is the charm revision to upgrade to. In this guide’s example, we will refresh the charm back to revision 88
It is necessary to re-run pre-upgrade-check
action on the leader unit, to enter the upgrade recovery state:
juju run mysql-k8s/leader pre-upgrade-check
Step 2: Rollback
When using charm from charmhub:
juju refresh mysql-k8s --revision=88
When deploying from a local charm file, one must have the previous revision charm file and the mysql-image
resource, then run:
juju refresh mysql-k8s --path=<path to charm file> --resource mysql-image=<image URL>
For example:
juju refresh mysql-k8s --path=./mysql-k8s_ubuntu-22.04-amd64.charm \
--resource mysql-image=ghcr.io/canonical/charmed-mysql@sha256:753477ce39712221f008955b746fcf01a215785a215fe3de56f525380d14ad97
where
is the previous revision charm file.
The reference for the resource for a given revision can be found in the metadata.yaml
file in the charm’s repository under the key upstream-source
The first unit will be rolled out and should rejoin the cluster after settling down. After the refresh
command, the juju controller revision for the application will be back in sync with the running Charmed MySQL K8s revision.
Step 3: Resume
To resume the upgrade on the remaining units use the resume-upgrade
action:
juju run mysql-k8s/leader resume-upgrade
This will roll out the pods in the remaining units to the same charm revision.
Step 4: Check
Future improvements are planned to check the state on pods/clusters on a low level.
For now, check juju status
to make sure the cluster state is OK.
