Charmed MySQL K8s
8.0/stable 180 02 Sep 2024
8.0/stable 181 02 Sep 2024
8.0/candidate 180 26 Aug 2024
8.0/candidate 181 26 Aug 2024
8.0/beta 207 15 Nov 2024
8.0/beta 206 15 Nov 2024
8.0/edge 209 18 Nov 2024
8.0/edge 208 18 Nov 2024
Charm lifecycle flowcharts
Click to navigate the mermaid diagram on GitHub.
flowchart TD
    id101([leader_elected]) --> id102[generate\npassword/configs]
    id102 --> id103[store peer databag]
    id103 --> id104((return))
    id201([pebble_ready]) --> id202{if not `configured` \nnor peer relation}
    id202 --> id203>defer]
    id202 -- else --> id204[add pebble layer]
    id204 --> id205[configure mysql\nusers]
    id205 --> id206[configure instance\nfor GR]
    id206 --> id207{is leader?}
    id207 -- no --> id208((return))
    id207 -- yes --> id209[create GR cluster]
    id209 --> id208
    id301([peer_relation_changed\nor\nupdate_status]) --> id302{is waiting\nto join}
    id302 -- yes --> id303{is already\nin cluster?}
    id303 --> id304[get primary\nfrom any online peer]
    id304 --> id305[get current\ncluster node count]
    id305 --> id306{is cluster\nat max size}
    id306 -- no --> id307{is cluster\ntopology\nchanging}
    id307 --> id309[acquire topology\nchange token]
    id309 --> id310[join the cluster\nfrom primary]
    id310 --> id311[release token]
    id306 -- yes --> id308[Set blocked\nand standby]
    id302 -- no --> id399((return))
    id303 -- yes --> id399
    id307 --> id399
    id308 --> id399
    id311 --> id399
Help improve this document in the forum (guidelines). Last updated 1 year, 5 months ago.
