Temporal Server
- By Commercial Systems
latest/stable | 23 | 08 Mar 2024 | |
latest/edge | 24 | 09 Apr 2024 |
juju deploy temporal-k8s --channel edge
Charmed Temporal How-to
The How-to guides in this section give directions on how to achieve your goals when configuring, managing or using Charmed Temporal. These How-to guides are more useful when you are familiar with Temporal and seek to achieve specific goals such as enabling auth, observability and performing server upgrades.
The How-to guides will cover the following:
- Authentication: for enabling client authentication using Google OAuth.
- Authorization: for enabling client authorization using OpenFGA.
- Observability: for enabling observability metrics through the Canonical Observabiliy Stack.
- Scaling: for horizontally scaling your Charmed Temporal deployment.
- TCTL: for using the tctl command line tool.
- Server Upgrades: for safely upgrading Charmed Temporal server.
- Enabling Archival: for enabling workflow event history archival to an S3 bucket.
Also check out the Tutorial for step-by-step instructions that help you get started with Charmed Temporal, as well as the Reference section for other helpful information.
