Charmed PostgreSQL K8s
- By Canonical Data Platform
14/edge | 248 | 04 May 2024 |
Overview
The Reference section of our documentation contains pages for technical specifications, APIs, release notes, and other reference material for fast lookup.
In the left sidebar navigation, you will find the following references:
Page | Description |
Release Notes | Release notes for major revisions of this charm |
Requirements | Software and hardware requirements |
Testing | Software tests (e.g. smoke, unit, performance…) |
Troubleshooting | Troubleshooting tips and tricks |
Profiles | Config profiles related to performance |
Plugins/extensions | Plugins/extensions supported by each charm revision |
Contacts | Contact information |
In the tabs at the top of the page, you can find the following automatically generated API references:
Resources | Under construction |
Integrations | Integration/relation interfaces supported by this charm |
Libraries | Classes and interfaces used in the charm’s code |
Configuration | Application configuration parameters (more info here) |
Actions | Juju actions supported by this charm |
