Charmed PostgreSQL K8s
- By Canonical Data Platform
14/edge | 248 | 04 May 2024 |
Juju version
The charm supports both Juju 2.9 LTS and Juju 3.1.
Note: Juju 3.1 is supported from the charm revision 116+ only.
The minimum supported Juju versions are:
- 2.9.32+ (no tests made for older versions).
- 3.1.7+ (Juju secrets refactored/stabilized in Juju 3.1.7)
Kubernetes requirements
- Kubernetes 1.27+
- Canonical MicroK8s 1.27+ (snap channel 1.27-strict/stable and newer)
Minimum requirements
Make sure your machine meets the following requirements:
- Ubuntu 22.04 (Jammy) or later.
- 8GB of RAM.
- 2 CPU threads.
- Access to the internet for downloading the required OCI/ROCKs and charms.
Supported architectures
The charm is based on the charmed-postgresql snap. It currently supports:
amd64
arm64
(from revision 211+)
The charm is based on the ROCK OCI named charmed-postgresql
Contact us if you are interested in new architecture!
