Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 193 13 Mar 2024
14/candidate 248 Yesterday
14/beta 248 Yesterday
14/edge 248 Yesterday
How to deploy on GKE
Google Kubernetes Engine (GKE) is a highly scalable and fully automated Kubernetes service. To access the GKE Web interface, go to console.cloud.google.com/compute.
This guide will walk you through setting up a cluster and deploying PostgreSQL K8s on GKE.
Install GKE and Juju tooling
Install juju, kubectl, and Google Cloud command-line tools using snap:
sudo snap install kubectl --classic
sudo snap install google-cloud-cli --classic
Authenticate
Log in to a Google account with the command
gcloud auth login
This should open a page in your browser starting with https://accounts.google.com/o/oauth2/... where you can complete the login.
If successful, the command prompt will show:
You are now logged in as [<account>@gmail.com].
Configure project ID
Next, you must associate this installation with GCloud project using “Project ID” from resource-management:
gcloud config set project <PROJECT_ID>
Sample output:
Updated property [core/project].
Install additional gcloud CLI tool
As a last step, install the Debian package google-cloud-sdk-gke-gcloud-auth-plugin using this Google guide: Install the gcloud CLI.
Create a new GKE cluster
This guide will use high-availability zone europe-west1 and compute engine type n1-standard-4 in command examples. Make sure to choose the zone and resources that best suit your use-case.
The following command will start three compute engines on Google Cloud and deploy a K8s cluster (you can imagine the compute engines as three physical servers in clouds):
gcloud container clusters create --zone europe-west1-c $USER-$RANDOM --cluster-version 1.25 --machine-type n1-standard-4 --num-nodes=3 --no-enable-autoupgrade
Next, assign your account as an admin of the newly created K8s cluster:
kubectl create clusterrolebinding cluster-admin-binding-$USER --clusterrole=cluster-admin --user=$(gcloud config get-value core/account)
Bootstrap Juju on GKE
Bootstrap a new juju controller on the new cluster by running the following commands:
juju add-k8s gke-jun-9 --storage=standard --client
juju bootstrap gke-jun-9
juju add-model welcome-model
At this stage, Juju is ready to use GKE. Check the list of currently running K8s pods with:
kubectl get pods -n welcome-model
Deploy charms
The following commands deploy PostgreSQL K8s and PgBouncer K8s:
juju deploy postgresql-k8s --trust
To track the status of the postgresql-k8s app, run
juju status --watch 1s
List clusters and clouds
To list GKE clusters and juju clouds, run:
gcloud container clusters list
Sample output:
NAME          LOCATION        MASTER_VERSION   MASTER_IP      MACHINE_TYPE   NODE_VERSION     >NUM_NODES  STATUS
mykola-18187  europe-west1-c  1.25.9-gke.2300  31.210.22.127  n1-standard-4  1.25.9-gke.2300  3          >RUNNING
taurus-7485   europe-west1-c  1.25.9-gke.2300  142.142.21.25  n1-standard-4  1.25.9-gke.2300  3          >RUNNING
Juju can handle multiple clouds simultaneously. To see a list of clouds with registered credentials on Juju, run:
juju clouds
Sample output:
Clouds available on the controller:
Cloud      Regions  Default       Type
gke-jun-9  1        europe-west1  k8s
Cloud           Regions  Default       Type  Credentials  Source    Description
gke-jun-9       1        europe-west1  k8s   1            local     A Kubernetes Cluster
localhost       1        localhost     lxd   1            built-in  LXD Container Hypervisor
microk8s        0                      k8s   1            built-in  A local Kubernetes context
Clean up
Warning: Always clean GKE resources that are no longer necessary - they could be costly!
To clean GKE clusters and juju clouds, use:
juju destroy-controller gke-jun-9-europe-west1 --yes --destroy-all-models --destroy-storage --force
juju remove-cloud gke-jun-9
gcloud container clusters delete <cluster_name> --zone europe-west1-c
Revoke the GCloud user credentials:
gcloud auth revoke your_account@gmail.com
You should see a confirmation output:
Revoked credentials:
- your_account@gmail.com
