Charmed PostgreSQL K8s
- By Canonical Data Platform
14/edge | 248 | 04 May 2024 |
Configure S3 for RadosGW
juju run
injuju v.2.9
juju integrate
replacesjuju relate
andjuju add-relation
injuju v.2.9
A Charmed PostgreSQL backup can be stored on any S3-compatible storage. S3 access and configurations are managed with the s3-integrator charm.
This guide will teach you how to deploy and configure the s3-integrator charm on Ceph via RadosGW, send the configuration to a Charmed PostgreSQL application, and update it. (To configure S3 for AWS, see this guide)
Configure s3-integrator
First, install the MinIO client and create a bucket:
mc config host add dest https://radosgw.mycompany.fqdn <access-key> <secret-key> --api S3v4 --lookup path
mc mb dest/backups-bucket
Then, deploy and run the charm:
juju deploy s3-integrator
juju run s3-integrator/leader sync-s3-credentials access-key=<access-key> secret-key=<secret-key>
Lastly, use juju config
to add your configuration parameters. For example:
juju config s3-integrator \
endpoint="https://radosgw.mycompany.fqdn" \
bucket="backups-bucket" \
path="/postgresql" \
region="" \
s3-api-version="" \
s3-uri-style="path"
Integrate with Charmed PostgreSQL
To pass these configurations to Charmed PostgreSQL, integrate the two applications:
juju integrate s3-integrator postgresql-k8s
You can create, list, and restore backups now:
juju run postgresql-k8s/leader list-backups
juju run postgresql-k8s/leader create-backup
juju run postgresql-k8s/leader restore backup-id=<backup-id-here>
You can also update your S3 configuration options after relating, using:
juju config s3-integrator <option>=<value>
The s3-integrator charm accepts many configurations - enter whatever configurations are necessary for your S3 storage.
MicroCeph tip: Make sure the region
for s3-integrator
matches "sudo microceph.radosgw-admin zonegroup list"
output (use region="default"
by default).
