Charmed PostgreSQL K8s
- By Canonical Data Platform
14/edge | 251 | 08 May 2024 |
How to deploy and manage units
juju run
injuju v.2.9
juju integrate
replacesjuju relate
andjuju add-relation
injuju v.2.9
Basic Usage
To deploy a single unit of PostgreSQL using its default configuration, run:
juju deploy postgresql-k8s --channel 14/stable
It is customary to use PostgreSQL with replication. Hence, usually more than one unit (preferably an odd number to prohibit a “split-brain” scenario) is deployed.
To deploy PostgreSQL with multiple replicas, specify the number of desired units with the -n
option:
juju deploy postgresql-k8s --channel 14/stable -n <number_of_replicas>
To retrieve the primary replica, one can use the action get-primary
on any of the units running postgresql-k8s:
juju run postgresql-k8s/leader get-primary
Similarly, the primary replica is displayed as a status message in juju status
. However, one should note that this hook gets called on regular time intervals and the primary may be outdated if the status hook has not been called recently.
We highly suggest configuring the status hook to run frequently. In addition to reporting the primary, secondaries, and other statuses, the status hook performs self-healing in the case of a network cut.
To change the frequency of the update-status
hook, run
juju model-config update-status-hook-interval=<time(s/m/h)>
Note that this hook executes a read query to PostgreSQL. On a production level server, this should be configured to occur at a frequency that doesn’t overload the server with read requests. Similarly, the hook should not be configured at too quick of a frequency, as this can delay other hooks from running. You can read more about status hooks here.
Replication
Both scaling up and scaling down operations are performed using juju scale-application
juju scale-application postgresql-k8s <desired_num_of_units>
Warning: Scaling down to zero units will destroy your data!
