| 1/stable | 408 | 18 Feb 2025 | |
| 1/stable | 407 | 18 Feb 2025 | |
| 1/candidate | 408 | 14 Feb 2025 | |
| 1/candidate | 407 | 14 Feb 2025 | |
| 1/beta | 408 | 07 Feb 2025 | |
| 1/beta | 407 | 07 Feb 2025 | |
| 1/edge | 498 | 02 Dec 2025 | |
| 1/edge | 497 | 02 Dec 2025 |
juju deploy pgbouncer-k8s --channel 1/edge --trust
Juju version
The charm supports both Juju 2.9 LTS and Juju 3.x. The supported Juju versions are:
- 3.6.1+ LTS (recommended)
- 3.1.7+ (minimal for 3.x: Juju secrets refactored/stabilized in Juju 3.1.7)
- 2.9.32+ (minimal for 2.x)
Kubernetes requirements
- Kubernetes 1.27+
- Canonical MicroK8s 1.27+ (snap channel 1.27-strict/stable and newer)
Minimum requirements
Make sure your machine meets the following requirements:
- Ubuntu 22.04 (Jammy) or later.
- 8GB of RAM.
- 2 CPU threads.
- Access to the internet for downloading the required OCI/ROCKs and charms.
Supported architectures
The charm is based on ROCK OCI named “charmed-postgresql”, which is recursively based on SNAP “charmed-postgresql”, which is currently available for amd64 and arm64 (revision 146+). Please contact us if you are interested in new architecture!
Charmed PostgreSQL K8s requirements
Please also keep in mind “Charmed PostgreSQL K8s” requirements.
