pgbouncer-k8s
Charmed PgBouncer K8s
1/stable 408 18 Feb 2025
1/stable 407 18 Feb 2025
1/candidate 408 14 Feb 2025
1/candidate 407 14 Feb 2025
1/beta 408 07 Feb 2025
1/beta 407 07 Feb 2025
1/edge 498 02 Dec 2025
1/edge 497 02 Dec 2025
juju deploy pgbouncer-k8s --channel 1/edge --trust
Enable tracing
This guide contains the steps to enable tracing with Grafana Tempo for your PgBouncer K8s application.
To summarize:
This feature is available for Charmed PgBouncer K8s revision 162+ only.
Deploy Tempo
Then, deploy the dependencies of Tempo by following this tutorial. In particular, we would want to:
  • Deploy the minio charm
  • Deploy the s3 integrator charm
  • Add a bucket in minio using a python script
  • Configure s3 integrator with the minio credentials
Finally, deploy and integrate with Tempo HA in a monolithic setup.
Offer interfaces
Next, offer interfaces for cross-model integrations from the model where Charmed PgBouncer K8s is deployed.
juju offer <tempo_coordinator_k8s_application_name>:tracing
Then, switch to the Charmed PgBouncer K8s model, find the offers, and integrate (relate) with them:
juju switch <k8s_controller_name>:<pgbouncer_k8s_model_name>
:exclamation: Do not miss the “:” in the command above.
Store  URL                            Access  Interfaces
k8s    admin/cos.tempo                admin   tracing:tracing
juju consume k8s:admin/cos.tempo
Consume interfaces
Relate Charmed PgBouncer K8s with the above consumed interface:
First, deploy Grafana Agent K8s from the latest/edge channel:
juju deploy grafana-agent-k8s --channel latest/edge
Then, integrate Grafana Agent K8s with the consumed interface from the previous section:
juju integrate grafana-agent-k8s:tracing tempo:tracing
Finally, integrate Charmed PgBouncer K8s with Grafana Agent K8s:
juju integrate pgbouncer-k8s:tracing grafana-agent-k8s:tracing-provider
Wait until the model settles. The following is an example of the juju status --relations on the Charmed PgBouncer K8s model:
database  k8s        microk8s/localhost   3.5.4    unsupported  18:12:15Z
SAAS   Status  Store       URL
tempo  active  k8s         admin/cos.tempo
App                  Version  Status  Scale  Charm                Channel        Rev  Address         Exposed  Message
grafana-agent-k8s    0.40.4   active      1  grafana-agent-k8s    latest/edge     93  10.152.183.52   no       grafana-dashboards-provider: off, logging-consumer: off, send-remote-write: off
pgbouncer-k8s        1.21.0   active      1  pgbouncer-k8s                         0  10.152.183.202  no
postgresql-k8s       14.13    active      1  postgresql-k8s       14/edge        410  10.152.183.168  no
postgresql-test-app           active      1  postgresql-test-app  latest/stable  211  10.152.183.174  no       received database credentials of the first database
Unit                    Workload  Agent  Address       Ports  Message
grafana-agent-k8s/0*    active    idle   10.1.241.205         grafana-dashboards-provider: off, logging-consumer: off, send-remote-write: off
pgbouncer-k8s/0*        active    idle   10.1.241.202
postgresql-k8s/0*       active    idle   10.1.241.204         Primary
postgresql-test-app/0*  active    idle   10.1.241.203         received database credentials of the first database
Integration provider                       Requirer                                   Interface              Type     Message
grafana-agent-k8s:peers                    grafana-agent-k8s:peers                    grafana_agent_replica  peer
grafana-agent-k8s:tracing-provider         pgbouncer-k8s:tracing                      tracing                regular
pgbouncer-k8s:database                     postgresql-test-app:database               postgresql_client      regular
pgbouncer-k8s:pgb-peers                    pgbouncer-k8s:pgb-peers                    pgb_peers              peer
pgbouncer-k8s:upgrade                      pgbouncer-k8s:upgrade                      upgrade                peer
postgresql-k8s:database                    pgbouncer-k8s:backend-database             postgresql_client      regular
postgresql-k8s:database-peers              postgresql-k8s:database-peers              postgresql_peers       peer
postgresql-k8s:restart                     postgresql-k8s:restart                     rolling_op             peer
postgresql-k8s:upgrade                     postgresql-k8s:upgrade                     upgrade                peer
postgresql-test-app:postgresql-test-peers  postgresql-test-app:postgresql-test-peers  postgresql-test-peers  peer
tempo:tracing                              grafana-agent-k8s:tracing                  tracing                regular
View traces
After this is complete, the Tempo traces will be accessible from Grafana under the Explore section with tempo-k8s as the data source. You will be able to select pgbouncer-k8s as the Service Name under the Search tab to view traces belonging to Charmed PgBouncer K8s.
Below is a screenshot demonstrating a Charmed PgBouncer K8s trace:
Feel free to read through the Tempo HA documentation at your leisure to explore its deployment and its integrations.
