We've discontinued the registration of new Bundles
New Bundle registrations are no longer accepted. Existing bundles remain functional. We recommend using the Juju Terraform Provider for new deployments.
Kubeflow
Kubeflow Charmers Publisher | bundle
Channel Revision Published
latest/beta 430 30 Aug 2024
latest/edge 438 30 Jun 2025
1.10/stable 447 19 Feb 2026
1.10/candidate 448 19 Feb 2026
1.10/beta 442 28 Jan 2026
1.10/edge 442 28 Jan 2026
1.11/stable 450 15 Apr 2026
1.11/candidate 449 03 Mar 2026
1.11/beta 452 17 Aug 2026
1.11/edge 445 18 Feb 2026
1.9/stable 432 03 Dec 2024
1.9/beta 420 19 Jul 2024
1.9/edge 431 03 Dec 2024
1.8/stable 414 22 Nov 2023
1.8/beta 411 22 Nov 2023
1.8/edge 413 22 Nov 2023
1.7/stable 409 27 Oct 2023
1.7/beta 408 27 Oct 2023
1.7/edge 407 27 Oct 2023
juju deploy kubeflow --channel latest/beta
This guide describes how to configure Charmed Kubeflow to perform inference on user owned KServe Inference Services (ISVCs) using programmatic access tokens, for example from a Jupyter Notebook.
To do so, follow these steps:
  1. Create a ServiceAccount token from inside a Notebook server with the following parameters:
TOKEN=$(kubectl create token \
    default-editor \
    --duration=<duration in s> \
    --audience=istio-ingressgateway.kubeflow.svc.cluster.local)
The --audience parameter has to be set to istio-ingressgateway.kubeflow.svc.cluster.local for requests with this token to go through, otherwise they can be rejected.
  1. Pass the TOKEN to the request, for example:
curl $ISVC_URL/v1/models/model-endpoint \
    -H "Authorization: Bearer $TOKEN" \
    -H 'Content-Type: <content-type>' \
    -d <data>
The ServiceAccount token is bound to the default-editor ServiceAccount that gets created for every Charmed Kubeflow user. That being said:
  • The token will not be valid if the default-editor ServiceAccount is deleted.
  • The access cannot be revoked unless the duration set at creation time has expired.
Help improve this document in the forum (guidelines). Last updated 1 year, 6 months ago.
