Kubeflow
| 1.10/stable | 447 | 19 Feb 2026 |
| 1.10/candidate | 448 | 19 Feb 2026 |
| 1.10/beta | 442 | 28 Jan 2026 |
| 1.10/edge | 442 | 28 Jan 2026 |
| 1.11/stable | 450 | 15 Apr 2026 |
| 1.11/candidate | 449 | 03 Mar 2026 |
| 1.11/beta | 446 | 18 Feb 2026 |
| 1.11/edge | 445 | 18 Feb 2026 |
juju deploy kubeflow --channel latest/beta
This guide describes how to configure Charmed Kubeflow to perform inference on user owned KServe Inference Services (ISVCs) using programmatic access tokens, for example from a Jupyter Notebook.
To do so, follow these steps:
- Create a
ServiceAccounttoken from inside a Notebook server with the following parameters:
TOKEN=$(kubectl create token \
default-editor \
--duration=<duration in s> \
--audience=istio-ingressgateway.kubeflow.svc.cluster.local)
The --audience parameter has to be set to istio-ingressgateway.kubeflow.svc.cluster.local for requests with this token to go through, otherwise they can be rejected.
- Pass the
TOKENto the request, for example:
curl $ISVC_URL/v1/models/model-endpoint \
-H "Authorization: Bearer $TOKEN" \
-H 'Content-Type: <content-type>' \
-d <data>
The ServiceAccount token is bound to the default-editor ServiceAccount that gets created for every Charmed Kubeflow user. That being said:
- The token will not be valid if the
default-editor ServiceAccountis deleted. - The access cannot be revoked unless the
durationset at creation time has expired.
