Prometheus scrape target
- By Canonical Observability
latest/stable | 34 | 10 Apr 2024 | |
latest/candidate | 34 | 26 Mar 2024 | |
latest/beta | 34 | 12 Mar 2024 | |
latest/edge | 34 | 29 Feb 2024 | |
1.0/stable | 31 | 12 Dec 2023 | |
1.0/candidate | 31 | 22 Nov 2023 | |
1.0/beta | 31 | 22 Nov 2023 | |
1.0/edge | 31 | 22 Nov 2023 |
juju deploy prometheus-scrape-target-k8s --channel 1.0/edge
Metadata
Key | Value |
Summary | Deploy the COS Lite observability stack on MicroK8s. |
Categories | deploy-applications |
Difficulty | 2 |
Author | Leon Mintz |
Contents:
- Introduction
- Configure MicroK8s
- Deploy the COS Lite bundle
- Deploy the COS Lite bundle with overlays
- Browse dashboards
- Next steps
- Further reading
Introduction
The COS Lite bundle is a Juju-based observability stack, running on Kubernetes. The bundle consists of Prometheus, Loki, Alertmanager and Grafana.
Let’s go and deploy that bundle!
Configure MicroK8s
For the COS Lite bundle deployment to go smoothly, make sure the following MicroK8s addons are enabled: dns
, hostpath-storage
and metallb
You can check this with microk8s status
, and if any are missing, enable them with
microk8s enable dns
microk8s enable hostpath-storage
The bundle comes with Traefik to provide ingress, for which the metallb
addon should be enabled:
IPADDR=$(ip -4 -j route get 2.2.2.2 | jq -r '.[] | .prefsrc')
microk8s enable metallb:$IPADDR-$IPADDR
To wait for all the addons to be rolled out,
microk8s kubectl rollout status deployments/hostpath-provisioner -n kube-system -w
microk8s kubectl rollout status deployments/coredns -n kube-system -w
microk8s kubectl rollout status daemonset.apps/speaker -n metallb-system -w
If you have an HTTP proxy configured, you will need to give this information to MicroK8s. See the proxy docs for details.
By default, MicroK8s will use 8.8.8.8 and 8.8.4.4 as DNS servers, which can be adjusted. See the dns docs for details.
It is usually a good idea to create a dedicated model for the COS Lite bundle. So let’s do just that and call the new model cos
juju add-model cos
juju switch cos
Next, deploy the bundle with:
juju deploy cos-lite --trust
Now you can sit back and watch the deployment take place:
watch --color juju status --color --relations
The status of your deployment should eventually be very similar to the following:
> juju status --relations
cos charm-dev microk8s/localhost 2.9.42 unsupported 15:43:36-04:00
alertmanager 0.25.0 active 1 alertmanager-k8s edge 67 10.152.183.93 no
catalogue active 1 catalogue-k8s edge 15 10.152.183.193 no
grafana 9.2.1 active 1 grafana-k8s edge 77 10.152.183.137 no
loki 2.7.4 active 1 loki-k8s edge 82 10.152.183.119 no
prometheus 2.42.0 active 1 prometheus-k8s edge 122 10.152.183.51 no
traefik 2.9.6 active 1 traefik-k8s edge 125 10.43.8.34 no
alertmanager/0* active idle 10.1.55.34
catalogue/0* active idle 10.1.55.38
grafana/0* active idle 10.1.55.32
loki/0* active idle 10.1.55.14
prometheus/0* active idle 10.1.55.40
traefik/0* active idle 10.1.55.53
alertmanager:alerting loki:alertmanager alertmanager_dispatch regular
alertmanager:alerting prometheus:alertmanager alertmanager_dispatch regular
alertmanager:grafana-dashboard grafana:grafana-dashboard grafana_dashboard regular
alertmanager:grafana-source grafana:grafana-source grafana_datasource regular
alertmanager:replicas alertmanager:replicas alertmanager_replica peer
alertmanager:self-metrics-endpoint prometheus:metrics-endpoint prometheus_scrape regular
catalogue:catalogue alertmanager:catalogue catalogue regular
catalogue:catalogue grafana:catalogue catalogue regular
catalogue:catalogue prometheus:catalogue catalogue regular
grafana:grafana grafana:grafana grafana_peers peer
grafana:metrics-endpoint prometheus:metrics-endpoint prometheus_scrape regular
loki:grafana-dashboard grafana:grafana-dashboard grafana_dashboard regular
loki:grafana-source grafana:grafana-source grafana_datasource regular
loki:metrics-endpoint prometheus:metrics-endpoint prometheus_scrape regular
prometheus:grafana-dashboard grafana:grafana-dashboard grafana_dashboard regular
prometheus:grafana-source grafana:grafana-source grafana_datasource regular
prometheus:prometheus-peers prometheus:prometheus-peers prometheus_peers peer
traefik:ingress alertmanager:ingress ingress regular
traefik:ingress catalogue:ingress ingress regular
traefik:ingress-per-unit loki:ingress ingress_per_unit regular
traefik:ingress-per-unit prometheus:ingress ingress_per_unit regular
traefik:metrics-endpoint prometheus:metrics-endpoint prometheus_scrape regular
traefik:traefik-route grafana:ingress traefik_route regular
Now COS Lite is good to go: you can relate software with it to begin the monitoring!
Alternatively, you may want to deploy the bundle with one or more of our readily available overlays, which is what we’ll cover next.
An overlay is a set of model-specific modifications that avoid repetitive overhead in setting up bundles like COS Lite.
Specifically, we offer the following overlays:
the
offers
overlay makes your COS model ready for cross-model relations -
the
storage-small
overlay applies some defaults for the various storages used by the COS Lite components.
You can apply the offers
overlay do an existing COS Lite bundle by executing the juju deploy
command.
The storage-small
overlay, however, is applicable only on the first deployment.
So, if you were following the previous steps you would first need to switch to a new Juju model or remove all applications from the current one.
To use any of the overlays above, you need to include an --overlay
argument per overlay (applied in order):
curl -L https://raw.githubusercontent.com/canonical/cos-lite-bundle/main/overlays/offers-overlay.yaml -O
curl -L https://raw.githubusercontent.com/canonical/cos-lite-bundle/main/overlays/storage-small-overlay.yaml -O
juju deploy cos-lite \
--trust \
--overlay ./offers-overlay.yaml \
--overlay ./storage-small-overlay.yaml
Browse dashboards
When all the charms are deployed you can head over to browse their built-in web-UIs.
You can find out their addresses from the show-proxied-endpoints
traefik action. For example:
juju run traefik/0 show-proxied-endpoints --format=yaml \
| yq '."traefik/0".results."proxied-endpoints"' \
| jq
…should return output similar to:
"prometheus/0": {
"url": "http://10.43.8.34:80/cos-prometheus-0"
"loki/0": {
"url": "http://10.43.8.34:80/cos-loki-0"
"catalogue": {
"url": "http://10.43.8.34:80/cos-catalogue"
"alertmanager": {
"url": "http://10.43.8.34:80/cos-alertmanager"
In the output above,
10.43.8.34
is traefik’s IP address.- Applications that are ingresses “per app”, such as alertmanager, are accessible via the
model-app
path (i.e.http://10.43.8.34:80/cos-alertmanager
). - Applications that are ingresses “per unit”, such as loki, are accessible via the
model-app-unit
path (i.e.http://10.43.8.34:80/cos-loki-0
Note that Grafana does not appear in the list. Currently, to obtain Grafana’s proxied endpoint you would need to look at catalogue’s relation data directly - try running:
juju show-unit catalogue/0 | grep url
…which should return a list of the endpoints like this:
url: http://10.43.8.34:80/cos-catalogue
url: http://10.43.8.34/cos-grafana
url: http://10.43.8.34:80/cos-prometheus-0
url: http://10.43.8.34:80/cos-alertmanager
With ingress in place, you can still access the workloads via pod IPs, but you will need to include the original port, as well as the ingress path. For example:
curl 10.1.55.34:9093/cos-alertmanager/-/ready
The default password for Grafana is automatically generated for every installation. To access Grafana’s web interface, use the username admin
, and the password obtained from the get-admin-password
action, e.g:
juju run grafana/leader get-admin-password --model cos
Enjoy!
Next steps
- Use the scrape target charm to have the COS stack scrape any Prometheus compatible metrics target.
- Relate your own charm to the COS stack with relation interfaces such as
prometheus_scrape
. - Configure alertmanager to have alerts routed to your receivers.
- Use the cos-proxy machine charm to observe LMA-enabled machine charms.
- Use the grafana-agent machine charm to observe charms on other substrates than Kubernetes.
If you need support, the charmhub community is the best place to get all your questions answered and get in touch with the community.
