Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 445 12 Nov 2024
14/stable 444 12 Nov 2024
14/candidate 463 19 Nov 2024
14/candidate 462 19 Nov 2024
14/beta 463 19 Nov 2024
14/beta 462 19 Nov 2024
14/edge 465 Yesterday
14/edge 464 Yesterday
Overview
The Reference section of our documentation contains pages for technical specifications, APIs, release notes, and other reference material for fast lookup.
In the left sidebar navigation, you will find the following references:
Page Description
Release Notes Release notes for major revisions of this charm
Requirements Software and hardware requirements
Testing Software tests (e.g. smoke, unit, performance…)
Troubleshooting Troubleshooting tips and tricks
Profiles Config profiles related to performance
Plugins/extensions Plugins/extensions supported by each charm revision
Contacts Contact information
In the tabs at the top of the page, you can find the following automatically generated API references:
Page Description
Resources :construction: Under construction
Integrations Integration/relation interfaces supported by this charm
Libraries Classes and interfaces used in the charm’s code
Configuration Application configuration parameters (more info here)
Actions Juju actions supported by this charm
Help improve this document in the forum (guidelines). Last updated 7 months ago.
