pgbouncer-k8s
PgBouncer K8s
1/stable 520 02 Mar 2026
1/stable 519 02 Mar 2026
1/candidate 520 27 Feb 2026
1/candidate 519 27 Feb 2026
1/beta 520 27 Feb 2026
1/beta 519 27 Feb 2026
1/edge 525 05 Mar 2026
1/edge 524 05 Mar 2026
juju deploy pgbouncer-k8s --channel 1/edge --trust
Releases
This page provides high-level overviews of the dependencies and features that are supported by each revision in every stable release. To learn more about the different release tracks, see the Juju documentation about risk levels.
To see all releases and commits, check the Charmed PgBouncer K8s releases on GitHub.
Dependencies and supported features
For each release, this table shows:
  • The PgBouncer version packaged inside
  • The minimum Juju version required to reliably operate all features of the release
    This charm still supports older versions of Juju 2.9. See the system requirements for more details
  • Support for specific features
Revision PgBouncer version Juju version TLS encryption COS monitoring Minor version upgrades
519, 520 1.21.0 3.6.14+ check check check
407, 408 1.21.0 3.6.1+ check check check
359, 360 1.21.0 3.4.5+ check check check
268, 269 1.21.0 3.4.5+ check check check
228, 229 1.21.0 3.4.5+ check check
144, 145 1.21.0 3.1.8+ check check
103 1.21.0 3.1.7+ check check
81 1.21.0 3.1.6+ check
76 1.18.0 3.1.6+ check
Architecture and base
Several revisions are released simultaneously for different bases/series using the same charm code. In other words, one release contains multiple revisions.
If you do not specify a revision on deploy time, Juju will automatically choose the revision that matches your base and architecture.
If you deploy a specific revision, you must make sure it matches your base and architecture via the tables below or with juju info.
Release 407, 408
Revision amd64 arm64 Ubuntu 22.04 (jammy)
519 check check
520 check check
[details=Older releases]
Release 407, 408
407 check check
408 check check
Older releases
Release 359, 360
360 check check
359 check check
Release 268, 269
268 check check
269 check check
Release 228, 229
228 check check
229 check check
Release 144,145
144 check check
145 check check
Release 103
103 check check
Release 81
81 check check
Release 76
81 check check
Note: Our release notes are an ongoing work in progress. If there is any additional information about releases that you would like to see or suggestions for other improvements, don’t hesitate to contact us on Matrix or leave a comment.
