Mimir Charmed Operator
2/stable 58 13 Nov 2025
Ubuntu 24.04
2/candidate 58 08 Oct 2025
Ubuntu 24.04
2/beta 58 31 Mar 2026
Ubuntu 24.04
2/edge 58 11 Sep 2025
Ubuntu 24.04
dev/edge 70 27 Apr 2026
Ubuntu 24.04
1/stable 50 08 Jul 2025
1/candidate 50 26 Jun 2025
1/beta 50 10 Jun 2025
1/edge 50 14 May 2025
juju deploy mimir-worker-k8s --channel dev/edge
Metadata
Key Value
Summary Deploy the COS Lite observability stack on MicroK8s.
Categories deploy-applications
Difficulty 2
Author Leon Mintz
Contents:
Introduction
The COS Lite bundle is a Juju-based observability stack, running on Kubernetes. The bundle consists of Prometheus, Loki, Alertmanager and Grafana.
This tutorial assumes you have a Juju controller bootstrapped on a MicroK8s cloud that is ready to use. A typical setup using snaps can be found in the Juju docs. Follow the instructions there to install Juju and MicroK8s.
Let’s go and deploy that bundle!
Configure MicroK8s
For the COS Lite bundle deployment to go smoothly, make sure the following MicroK8s addons are enabled: dns, hostpath-storage and metallb.
You can check this with microk8s status, and if any are missing, enable them with
microk8s enable dns
microk8s enable hostpath-storage
The bundle comes with Traefik to provide ingress, for which the metallb addon should be enabled:
IPADDR=$(ip -4 -j route get 2.2.2.2 | jq -r '.[] | .prefsrc')
microk8s enable metallb:$IPADDR-$IPADDR
To wait for all the addons to be rolled out,
microk8s kubectl rollout status deployments/hostpath-provisioner -n kube-system -w
microk8s kubectl rollout status deployments/coredns -n kube-system -w
microk8s kubectl rollout status daemonset.apps/speaker -n metallb-system -w
If you have an HTTP proxy configured, you will need to give this information to MicroK8s. See the proxy docs for details.
By default, MicroK8s will use 8.8.8.8 and 8.8.4.4 as DNS servers, which can be adjusted. See the dns docs for details.
Deploy the COS Lite bundle
It is usually a good idea to create a dedicated model for the COS Lite bundle. So let’s do just that and call the new model cos:
juju add-model cos
juju switch cos
Next, deploy the bundle with:
juju deploy cos-lite --trust
Now you can sit back and watch the deployment take place:
watch --color juju status --color --relations
The status of your deployment should eventually be very similar to the following:
> juju status --relations
Model  Controller  Cloud/Region        Version  SLA          Timestamp
cos    charm-dev   microk8s/localhost  2.9.42   unsupported  15:43:36-04:00
App           Version  Status  Scale  Charm             Channel  Rev  Address         Exposed  Message
alertmanager  0.25.0   active      1  alertmanager-k8s  edge      67  10.152.183.93   no
catalogue              active      1  catalogue-k8s     edge      15  10.152.183.193  no
grafana       9.2.1    active      1  grafana-k8s       edge      77  10.152.183.137  no
loki          2.7.4    active      1  loki-k8s          edge      82  10.152.183.119  no
prometheus    2.42.0   active      1  prometheus-k8s    edge     122  10.152.183.51   no
traefik       2.9.6    active      1  traefik-k8s       edge     125  10.43.8.34      no
Unit             Workload  Agent  Address     Ports  Message
alertmanager/0*  active    idle   10.1.55.34
catalogue/0*     active    idle   10.1.55.38
grafana/0*       active    idle   10.1.55.32
loki/0*          active    idle   10.1.55.14
prometheus/0*    active    idle   10.1.55.40
traefik/0*       active    idle   10.1.55.53
Relation provider                   Requirer                     Interface              Type     Message
alertmanager:alerting               loki:alertmanager            alertmanager_dispatch  regular
alertmanager:alerting               prometheus:alertmanager      alertmanager_dispatch  regular
alertmanager:grafana-dashboard      grafana:grafana-dashboard    grafana_dashboard      regular
alertmanager:grafana-source         grafana:grafana-source       grafana_datasource     regular
alertmanager:replicas               alertmanager:replicas        alertmanager_replica   peer
alertmanager:self-metrics-endpoint  prometheus:metrics-endpoint  prometheus_scrape      regular
catalogue:catalogue                 alertmanager:catalogue       catalogue              regular
catalogue:catalogue                 grafana:catalogue            catalogue              regular
catalogue:catalogue                 prometheus:catalogue         catalogue              regular
grafana:grafana                     grafana:grafana              grafana_peers          peer
grafana:metrics-endpoint            prometheus:metrics-endpoint  prometheus_scrape      regular
loki:grafana-dashboard              grafana:grafana-dashboard    grafana_dashboard      regular
loki:grafana-source                 grafana:grafana-source       grafana_datasource     regular
loki:metrics-endpoint               prometheus:metrics-endpoint  prometheus_scrape      regular
prometheus:grafana-dashboard        grafana:grafana-dashboard    grafana_dashboard      regular
prometheus:grafana-source           grafana:grafana-source       grafana_datasource     regular
prometheus:prometheus-peers         prometheus:prometheus-peers  prometheus_peers       peer
traefik:ingress                     alertmanager:ingress         ingress                regular
traefik:ingress                     catalogue:ingress            ingress                regular
traefik:ingress-per-unit            loki:ingress                 ingress_per_unit       regular
traefik:ingress-per-unit            prometheus:ingress           ingress_per_unit       regular
traefik:metrics-endpoint            prometheus:metrics-endpoint  prometheus_scrape      regular
traefik:traefik-route               grafana:ingress              traefik_route          regular
Now COS Lite is good to go: you can relate software with it to begin the monitoring!
Alternatively, you may want to deploy the bundle with one or more of our readily available overlays, which is what we’ll cover next.
Deploy the COS Lite bundle with overlays
An overlay is a set of model-specific modifications that avoid repetitive overhead in setting up bundles like COS Lite.
Specifically, we offer the following overlays:
You can apply the offers overlay to an existing COS Lite bundle by executing the juju deploy command. The storage-small overlay, however, is applicable only on the first deployment. So, if you were following the previous steps you would first need to switch to a new Juju model or remove all applications from the current one.
To use any of the overlays above, you need to include an --overlay argument per overlay (applied in order):
curl -L https://raw.githubusercontent.com/canonical/cos-lite-bundle/main/overlays/offers-overlay.yaml -O
curl -L https://raw.githubusercontent.com/canonical/cos-lite-bundle/main/overlays/storage-small-overlay.yaml -O
juju deploy cos-lite \
  --trust \
  --overlay ./offers-overlay.yaml \
  --overlay ./storage-small-overlay.yaml
Browse dashboards
When all the charms are deployed you can head over to browse their built-in web-UIs. You can find out their addresses from the show-proxied-endpoints traefik action. For example:
juju run traefik/0 show-proxied-endpoints --format=yaml \
  | yq '."traefik/0".results."proxied-endpoints"' \
  | jq
…should return output similar to:
  "prometheus/0": {
    "url": "http://10.43.8.34:80/cos-prometheus-0"
  "loki/0": {
    "url": "http://10.43.8.34:80/cos-loki-0"
  "catalogue": {
    "url": "http://10.43.8.34:80/cos-catalogue"
  "alertmanager": {
    "url": "http://10.43.8.34:80/cos-alertmanager"
In the output above,
  • 10.43.8.34 is traefik’s IP address.
  • Applications that are ingresses “per app”, such as alertmanager, are accessible via the model-app path (i.e. http://10.43.8.34:80/cos-alertmanager).
  • Applications that are ingresses “per unit”, such as loki, are accessible via the model-app-unit path (i.e. http://10.43.8.34:80/cos-loki-0).
Note that Grafana does not appear in the list. Currently, to obtain Grafana’s proxied endpoint you would need to look at catalogue’s relation data directly - try running:
juju show-unit catalogue/0 | grep url
…which should return a list of the endpoints like this:
      url: http://10.43.8.34:80/cos-catalogue
      url: http://10.43.8.34/cos-grafana
      url: http://10.43.8.34:80/cos-prometheus-0
      url: http://10.43.8.34:80/cos-alertmanager
With ingress in place, you can still access the workloads via pod IPs, but you will need to include the original port, as well as the ingress path. For example:
curl 10.1.55.34:9093/cos-alertmanager/-/ready
The default password for Grafana is automatically generated for every installation. To access Grafana’s web interface, use the username admin, and the password obtained from the get-admin-password action, e.g:
juju run grafana/leader get-admin-password --model cos
Enjoy!
Next steps
If you need support, the charmhub community is the best place to get all your questions answered and get in touch with the community.
Further reading
