kafka-k8s
Apache Kafka - K8s
latest/stable 5 09 Mar 2022
Ubuntu 20.04
latest/edge 27 25 Apr 2023
Ubuntu 22.04 Ubuntu 20.04
latest/edge 13 21 Oct 2022
3/stable 56 27 Feb 2024
3/candidate 56 27 Feb 2024
3/beta 82 03 Apr 2025
3/edge 82 31 Mar 2025
This is part of the Charmed Apache Kafka K8s Tutorial. Please refer to this page for more information and an overview of the content.
Transport Layer Security (TLS)
TLS is used to encrypt data exchanged between two applications; it secures data transmitted over the network. Typically, enabling TLS within a highly available database, and between a highly available database and client/server applications, requires domain-specific knowledge and a high level of expertise. Fortunately, the domain-specific knowledge has been encoded into Charmed Apache Kafka. This means (re-)configuring TLS on Charmed Apache Kafka is readily available and requires minimal effort on your end.
Again, relations come in handy here as TLS is enabled via relations; i.e. by relating Charmed Apache Kafka to the Self-signed Certificates Charm via the tls-certificates charm relations. The tls-certificates relation centralises TLS certificate management in a consistent manner and handles providing, requesting, and renewing TLS certificates, making it possible to use different providers, like the self-signed certificates but also other services, e.g. Let’s Encrypt.
In this tutorial, we will distribute self-signed certificates to all charms (Apache Kafka, Apache ZooKeeper, and client applications) that are signed using a root self-signed CA that is also trusted by all applications. This setup is only for show-casing purposes and self-signed certificates should never be used in a production cluster. For more information about which charm may better suit your use case, please refer to this post.
Configure TLS
Before enabling TLS on Charmed Apache Kafka we must first deploy the self-signed-certificates charm:
juju deploy self-signed-certificates --config ca-common-name="Tutorial CA"
Wait for the charm settle into an active/idle state, as shown by the juju status:
tutorial  microk8s    microk8s/localhost  3.1.5    unsupported  21:32:35+02:00
App                        Version  Status  Scale  Charm                      Channel    Rev  Exposed  Message
self-signed-certificates            active      1  self-signed-certificates   stable     72   no
Unit                          Workload  Agent  Address    Ports  Message
self-signed-certificates/0*   active    idle   10.1.36.91
To enable TLS on Charmed Apache Kafka K8s, relate the both the kafka-k8s and zookeeper-k8s charms with the self-signed-certificates charm:
juju relate zookeeper-k8s self-signed-certificates
juju relate kafka-k8s:certificates self-signed-certificates
After the charms settle into active/idle states, the Apache Kafka listeners should now have been swapped to the default encrypted port 9093. This can be tested by testing whether the ports are open/closed with telnet:
telnet <IP> 9092
telnet <IP> 9093
Enable TLS encrypted connection
Once TLS is configured on the cluster side, client applications should be configured as well to connect to the correct port and trust the self-signed CA provided by the self-signed-certificates charm.
Make sure that the kafka-test-app is not connected to the Charmed Apache Kafka, by removing the relation if it exists:
juju remove-relation kafka-test-app kafka-k8s
Then enable encryption on the kafka-test-app by relating with the self-signed-certificates charm:
juju relate kafka-test-app  self-signed-certificates
We can then set up the kafka-test-app to produce messages with the usual configuration (note that there is no difference here with the unencrypted workflow):
juju config kafka-test-app topic_name=test_encryption_topic role=producer num_messages=25
and then relate with the kafka-k8s cluster:
juju relate kafka-k8s kafka-test-app
As before, you can check that the messages are pushed into the Apache Kafka cluster by inspecting the logs:
juju exec --application kafka-test-app "tail /tmp/*.log"
Note that if the kafka-test-app was running before, there may be multiple logs related to the different runs. Refer to the latest logs produced and also check that in the logs the connection is indeed established with the encrypted port 9093.
Remove external TLS certificate
To remove the external TLS and return to the locally generated one, un-relate applications:
juju remove-relation kafka-k8s  self-signed-certificates
juju remove-relation zookeeper-k8s  self-signed-certificates
The Charmed Apache Kafka K8s application is not using TLS anymore.
Help improve this document in the forum (guidelines). Last updated 3 months ago.
