Kafka K8s
- By Canonical Data Platform
3/beta | 56 | 27 Feb 2024 | |
3/edge | 59 | 18 Apr 2024 |
Cluster Migration using MirrorMaker2.0
Overview
This How-To guide covers executing a cluster migration to a Charmed Kafka K8s deployment using MirrorMaker2.0, running as a process on each of the Juju units in an active/passive setup, where MirrorMaker will act as a consumer from an existing cluster, and a producer to the Charmed Kafka K8s cluster. In parallel (one process on each unit), data and consumer offsets for all existing topics will be synced one-way until both clusters are in-sync, with all data replicated across both in real-time.
MirrorMaker2 Overview
Under the hood, MirrorMaker uses Kafka Connect source connectors to replicate data, those being the following:
- MirrorSourceConnector - replicates topics from an original cluster to a new cluster. It also replicates ACLs and is necessary for the MirrorCheckpointConnector to run
- MirrorCheckpointConnector - periodically tracks offsets. If enabled, it also synchronizes consumer group offsets between the original and new clusters
- MirrorHeartbeatConnector - periodically checks connectivity between the original and new clusters
Together, these allow for cluster->cluster replication of topics, consumer groups, topic configuration and ACLs, preserving partitioning and consumer offsets. For more detail on MirrorMaker internals, consult the MirrorMaker README.md and the MirrorMaker 2.0 KIP. In practice, it allows one to sync data one-way between two live Kafka clusters with minimal impact on the ongoing production service.
In short, MirrorMaker runs as a distributed service on the new cluster, and consumes all topics, groups and offsets from the still-active original cluster in production, before producing them one-way to the new cluster that may not yet be serving traffic to external clients. The original, in-production cluster is referred to as an ‘active’ cluster, and the new cluster still waiting to serve external clients is ‘passive’. The MirrorMaker service can be configured using much the same configuration as available for Kafka Connect.
Deploy and run MirrorMaker
Pre-requisites
- An existing Kafka cluster to migrate from. The clusters need to be reachable from/to Charmed Kafka K8s.
- A bootstrapped Juju K8s cloud running Charmed Kafka K8s to migrate to
- A tutorial on how to set-up a Charmed Kafka deployment can be found as part of the Charmed Kafka K8s Tutorial
- The CLI tool
yq
- https://github.com/mikefarah/yq snap install yq --channel=v3/stable
Get cluster details and admin credentials
By design, the kafka
charm will not expose any available connections until related to by a client. In this case, we deploy data-integrator
charms and relating them to each kafka
application, requesting admin
level privileges:
juju deploy data-integrator --channel=edge -n 1 --config extra-user-roles="admin" --config topic-name="default"
juju relate kafka-k8s data-integrator
When the data-integrator
charm relates to a kafka-k8s
application on the kafka-client
relation interface, passing extra-user-roles=admin
, a new user with super.user
permissions will be created on that cluster, with the charm passing back the credentials and broker addresses in the relation data to the data-integrator
As we will need full access to both clusters, we must grab these newly-generated authorisation credentials from the data-integrator
# SASL credentials to connect to the Charmed Kafka cluster
export NEW_USERNAME=$(juju show-unit data-integrator/0 | yq -r '.. | .username? // empty')
export NEW_PASSWORD=$(juju show-unit data-integrator/0 | yq -r '.. | .password? // empty')
# list of bootstrap-server IPs
export NEW_SERVERS=$(juju show-unit data-integrator/0 | yq -r '.. | .endpoints? // empty')
# building full sasl.jaas.config for authorisation
export NEW_SASL_JAAS_CONFIG="org.apache.kafka.common.security.scram.ScramLoginModule required username=\""${NEW_USERNAME}"\" password=\""${NEW_PASSWORD}\"\;
Required source cluster credentials
In order to authenticate MirrorMaker to both clusters, it will need full super.user
permissions on BOTH clusters. MirrorMaker supports every possible security.protocol
supported by Apache Kafka. In this guide, we will make the assumption that the original cluster is using SASL_PLAINTEXT
authentication, as such, the required information is as follows:
# comma-separated list of kafka server IPs and ports to connect to
OLD_SERVERS
# string of sasl.jaas.config property
OLD_SASL_JAAS_CONFIG
NOTE - If using
SSL
orSASL_SSL
authentication, review the configuration options supported by Kafka Connect in the Apache Kafka documentation
Generating mm2.properties
file on the Charmed Kafka cluster
MirrorMaker takes a .properties
file for its configuration to fine-tune behavior. See below an example mm2.properties
file that can be placed on each of the Charmed Kafka units using the above credentials:
# Aliases for each cluster, can be set to any unique alias
clusters = old,new
# Specifies that data from 'old' should be consumed and produced to 'new', and NOT visa-versa, i.e 'active/passive' setup
old->new.enabled = true
new->old.enabled = false
# comma-separated list of kafka server IPs and ports to connect from both clusters
old.bootstrap.servers=$OLD_SERVERS
new.bootstrap.servers=$NEW_SERVERS
# sasl authentication config for each cluster, in this case using the 'admin' users created by the integrator charm for Charmed Kafka
old.sasl.jaas.config=$OLD_SASL_JAAS_CONFIG
new.sasl.jaas.config=$NEW_SASL_JAAS_CONFIG
# if not deployed with TLS, Charmed Kafka uses SCRAM-SHA-512 for SASL auth, with a SASL_PLAINTEXT listener
sasl.mechanism=SCRAM-SHA-512
security.protocol=SASL_PLAINTEXT
# keeps topic names consistent across clusters - see https://kafka.apache.org/30/javadoc/org/apache/kafka/connect/mirror/IdentityReplicationPolicy.html
replication.policy.class=org.apache.kafka.connect.mirror.IdentityReplicationPolicy
# pattern match for replicating all topics and all consumer groups
topics=.*
groups=.*
# the expected number of concurrent MirrorMaker tasks, usually set to match number of physical cores on the target cluster
tasks.max=3
# the new replication.factor for topics produced to the target cluster
replication.factor=2
# allows new topics and groups created mid-migration, to be copied
refresh.topics.enabled=true
sync.group.offsets.enabled=true
sync.topic.configs.enabled=true
refresh.topics.interval.seconds=5
refresh.groups.interval.seconds=5
sync.group.offsets.interval.seconds=5
emit.checkpoints.interval.seconds=5
# filters out records from aborted transactions
old.consumer.isolation.level=read_committed
new.consumer.isolation.level=read_committed
# Specific Connector configuration for ensuring Exactly-Once-Delivery (EOD)
# NOTE - EOD support guarantees released with Kafka 3.5.0 so some of these options may not work as expected
old.producer.enable.idempotence=true
new.producer.enable.idempotence=true
old.producer.acks=all
new.producer.acks=all
# old.exactly.once.support = enabled
# new.exactly.once.support = enabled
Once these properties have been generated (in this example, saved to /tmp/mm2.properties
), it is needed to place them on every Charmed Kafka unit:
cat /tmp/mm2.properties | juju ssh kafka-k8s/<id> sudo -i 'sudo tee -a /etc/kafka/mm2.properties'
where <id>
is the id of the Charmed Kafka unit.
Starting a dedicated MirrorMaker cluster
It is strongly advised to run MirrorMaker services on the downstream cluster to avoid service impact due to resource use. Now that the properties are set on each unit of the new cluster, the MirrorMaker services can be started using with JMX metrics exporters using the following:
# building KAFKA_OPTS env-var for running with an exporter
export KAFKA_OPTS = "-Djava.security.auth.login.config=/etc/kafka/zookeeper-jaas.cfg -javaagent:/opt/kafka/libs/jmx_prometheus_javaagent.jar=9099:/etc/kafka/jmx_kafka_connect.yaml"
# To start MM on kafka-k8s/<id> unit
juju ssh kafka-k8s/<id> sudo -i 'cd /opt/kafka/bin && KAFKA_OPTS=$KAFKA_OPTS ./connect-mirror-maker.sh /etc/kafka/mm2.properties'
Monitoring and validating data replication
The migration process can be monitored using built-in Kafka bin-commands on the original cluster. In the Charmed Kafka cluster, these bin-commands are also mapped to snap commands on the units (e.g charmed-kafka.get-offsets
or charmed-kafka.topics
To monitor the current consumer offsets, run the following on the original cluster being migrated from:
watch "bin/kafka-consumer-groups.sh --describe --offsets --bootstrap-server $OLD_SERVERS --all-groups
An example output of which may look similar to this:
GROUP TOPIC PARTITION CURRENT-OFFSET LOG-END-OFFSET LAG CONSUMER-ID HOST CLIENT-ID
admin-group-1 NEW-TOPIC 0 95 95 0 kafka-python-2.0.2-a95b3f90-75e9-4a16-b63e-5e021b7344c5 /10.248.204.1 kafka-python-2.0.2
admin-group-1 NEW-TOPIC 3 98 98 0 kafka-python-2.0.2-a95b3f90-75e9-4a16-b63e-5e021b7344c5 /10.248.204.1 kafka-python-2.0.2
admin-group-1 NEW-TOPIC 1 82 82 0 kafka-python-2.0.2-a95b3f90-75e9-4a16-b63e-5e021b7344c5 /10.248.204.1 kafka-python-2.0.2
admin-group-1 NEW-TOPIC 2 89 90 1 kafka-python-2.0.2-a95b3f90-75e9-4a16-b63e-5e021b7344c5 /10.248.204.1 kafka-python-2.0.2
admin-group-1 NEW-TOPIC 4 103 104 1 kafka-python-2.0.2-a95b3f90-75e9-4a16-b63e-5e021b7344c5 /10.248.204.1 kafka-python-2.0.2
There is also a range of different metrics made available by MirrorMaker during the migration. These can be accessed with something similar to:
curl 10.248.204.198:9099/metrics | grep records_count
Switching client traffic from original cluster to Charmed Kafka cluster
Once happy that all the necessary data has successfully migrated, stop all active consumer applications on the original cluster, and redirect them to the Charmed Kafka cluster, making sure to use the Charmed Kafka cluster server addresses and authentication. After doing so, they will re-join their original consumer groups at the last committed offset it had originally, and continue consuming as normal. Finally, the producer client applications can be stopped, updated with the Charmed Kafka cluster server addresses and authentication, and restarted, with any newly produced messages being received by the migrated consumer client applications, completing the migration of both the data, and the client applications.
Stopping MirrorMaker replication
Once confident in the successful completion of the data an client migration, the running processes on each of the charm units can be killed, stopping the MirrorMaker processes active on the Charmed Kafka cluster.
