kafka-k8s
Apache Kafka - K8s
latest/stable 5 09 Mar 2022
Ubuntu 20.04
latest/edge 27 25 Apr 2023
Ubuntu 22.04 Ubuntu 20.04
latest/edge 13 21 Oct 2022
3/stable 56 27 Feb 2024
3/candidate 56 27 Feb 2024
3/beta 82 03 Apr 2025
3/edge 82 31 Mar 2025
Manage message schemas
Message schemas in Apache Kafka define the structure and format of data exchanged between producers and consumers. This guide provides instructions on managing schemas in Charmed Apache Kafka using Karapace. Karapace is a drop-in replacement, open-source implementation of Confluent’s Schema Registry, and supports the storing of schemas in a central repository, which clients can access to serialize and deserialize messages written to Apache Kafka.
Follow the steps of the How to deploy Charmed Apache Kafka K8s guide to set up the environment. For this guide, we will need an active Charmed Apache Kafka application, related to an active Charmed Apache ZooKeeper application.
Deploy and set up Karapace
To deploy Karapace and integrate it with Apache Kafka, use the following commands:
juju deploy karapace --channel latest/edge
juju integrate karapace kafka-k8s
Once deployed, the password to access the Karapace REST API can be obtained:
juju run karapace/leader get-password username="operator"
To check that Karapace works correctly, list all registered schemas using the password from the previous command’s output:
curl -u operator:<password> -X GET http://<karapace-unit-ip>:8081/subjects
Registering a new schema
To register the first version of a schema <schema-name> with fields <field1> which is a string, and <field2> which is an integer using Avro schema, run:
curl -u operator:<password> -X POST -H "Content-Type: application/vnd.schemaregistry.v1+json" \
     http://<karapace-unit-ip>:8081/subjects/<schema-name>/versions \ --data '{"schema": "{\"type\": \"record\", \"name\": \"Obj\", \"fields\":[{\"name\": \"<field1>\", \"type\": \"string\"},{\"name\": \"<field2>\", \"type\": \"int\"}]}"}'
If successful, this should result in an output showing the global ID for this new schema:
{"id":1}
To register a version of the same schema above using JSON schema to a different subject with name <schema-name-json>, run:
    http://<karapace-unit-ip>:8081/subjects/<schema-name-json>/versions \
    --data '{"schemaType": "JSON", "schema": "{\"type\": \"object\",\"properties\":{\"<field1>\":{\"type\": \"string\"}, \"<field2>\":{\"type\": \"number\"}},\"additionalProperties\":true}"}'
If successful, this should result in output:
{"id":2}
Add new schema version
To test the compatibility of a schema with the latest schema version, for example <schema-name> schema with <field2> removed, run:
     http://<karapace-unit-ip>:8081/subjects/<schema-name>/versions/latest \
    --data '{"schema": "{\"type\": \"record\", \"name\": \"Obj\", \"fields\":[{\"name\": \"<field1>\", \"type\": \"string\"}]}"}'
If compatible, this will result in output:
{"is_compatible":true}
To register a new schema version, run:
Delete schema version
To delete a specific schema version:
curl -u operator:<password> -X DELETE http://<karapace-unit-ip>:8081/subjects/<schema-name>/versions/<schema-version>
To delete all versions of a schema:
curl -u operator:<password> -X DELETE http://<karapace-unit-ip>:8081/subjects/<schema-name-json>
