kafka-k8s
Apache Kafka - K8s
latest/stable 5 09 Mar 2022
Ubuntu 20.04
latest/edge 27 25 Apr 2023
Ubuntu 22.04 Ubuntu 20.04
latest/edge 13 21 Oct 2022
3/stable 56 27 Feb 2024
3/candidate 56 27 Feb 2024
3/beta 82 03 Apr 2025
3/edge 82 31 Mar 2025
How to deploy Charmed Apache Kafka K8s
For non-K8s Charmed Apache Apache Kafka, see the Charmed Apache Kafka documentation instead.
To deploy a Charmed Apache Kafka K8s cluster:
  1. Set up a Juju Controller
  2. Set up a Juju Model
  3. Deploy and relate Apache Kafka K8s and Apache ZooKeeper K8s charms.
  4. (Optionally) Create an external admin user
In the next subsections, we will cover these steps separately by referring to relevant Juju documentation and providing details on the Charmed Apache Kafka K8s specifics. If you already have a Juju controller and/or a Juju model, you can skip the associated steps.
Juju controller setup
Make sure you have a Juju controller accessible from your local environment using the Juju client snap.
List available controllers:
juju list-controllers
Switch to another controller if needed:
juju switch <controller>
If there are no suitable controllers, create a new one:
juju bootstrap <cloud> <controller>
where <cloud> – the cloud to deploy controller to, e.g., localhost. For more information on how to set up a new cloud, see the How to manage clouds guide in Juju documentation.
For more Juju controller setup guidance, see the How to manage controllers guide in Juju documentation.
Juju model setup
You can create a new Juju model using
juju add-model <model>
Alternatively, you can switch to any existing Juju model:
juju switch <model>
Make sure that the model is of a correct type (k8s):
juju show-model | yq '.[].type'
Deploy and relate Charmed Apache Kafka K8s and Charmed Apache ZooKeeper
Charmed Apache Kafka and Charmed Apache ZooKeeper can both be deployed as follows:
juju deploy kafka-k8s --channel 3/stable -n <kafka-units> --trust
juju deploy zookeeper-k8s --channel 3/stable -n <zookeeper-units> --trust
where <kafka-units> and <zookeeper-units> – the number of units to deploy for Charmed Apache Kafka and Charmed Apache ZooKeeper. We recommend values of at least 3 and 5 respectively.
The --trust option is needed for the Apache Kafka application to work properly, e.g., use NodePort or juju refresh. For more information about the trust options usage, see the Juju documentation.
Connect Charmed Apache ZooKeeper and Charmed Apache Kafka by relating/integrating them:
juju relate kafka-k8s zookeeper-k8s
Check the status of the deployment:
juju status
The deployment should be complete once all the units show active or idle status.
(Optional) Create an external admin users
Charmed Apache Kafka aims to follow the secure by default paradigm. As a consequence, after being deployed the Apache Kafka cluster won’t expose any external listener. In fact, ports are only opened when client applications are related, also depending on the protocols to be used.
For more information about the available listeners and protocols please refer to this table.
It is however generally useful for most situations to create a first admin user to be used to manage the Apache Kafka cluster (either internally or externally).
To create an admin user, deploy the Data Integrator Charm with extra-user-roles set to admin:
juju deploy data-integrator --channel stable --config topic-name=test-topic --config extra-user-roles=admin
… and relate it to the Apache Kafka K8s charm:
juju relate data-integrator kafka-k8s
To retrieve authentication information, such as the username and password, use:
