kafka-k8s
Apache Kafka - K8s
latest/stable 5 09 Mar 2022
Ubuntu 20.04
latest/edge 27 25 Apr 2023
Ubuntu 22.04 Ubuntu 20.04
latest/edge 13 21 Oct 2022
3/stable 56 27 Feb 2024
3/candidate 56 27 Feb 2024
3/beta 82 03 Apr 2025
3/edge 82 31 Mar 2025
How to enable encryption
The Apache Kafka K8s and Apache ZooKeeper K8s charms implement the Requirer side of the tls-certificates/v1 charm relation. Therefore, any charm implementing the Provider side could be used. To enable encryption, you should first deploy a TLS certificates Provider charm.
Deploy a TLS Provider charm
One possible option, suitable for testing, could be to use the self-signed-certificates charm. However, this setup is not recommended for production clusters.
To deploy a self-signed-certificates charm:
# deploy the TLS charm
juju deploy self-signed-certificates --channel=edge
# add the necessary configurations for TLS
juju config self-signed-certificates ca-common-name="Test CA"
Please refer to this post for an overview of the TLS certificates Providers charms and some guidance on how to choose the right charm for your use case.
Relate the charms
juju relate <tls-certificates> zookeeper-k8s
juju relate <tls-certificates> kafka-k8s:certificates
where <tls-certificates> is the name of the TLS certificate provider charm deployed.
If Apache Kafka K8s and Apache ZooKeeper K8s are already related, they will start renegotiating the relation to provide each other certificates and enable/open the correct ports/connections. Otherwise, relate them after the both relations with the <tls-certificates>.
Manage keys
Updates to private keys for certificate signing requests (CSR) can be made via the set-tls-private-key action.
# Updates can be done with auto-generated keys with
juju run kafka-k8s/<unit_id> set-tls-private-key
Passing keys to external/internal keys should only be done with base64 -w0 not cat, as follows:
# generate shared internal key
openssl genrsa -out internal-key.pem 3072
# apply keys on each unit
juju run kafka-k8s/<unit_id> set-tls-private-key "internal-key=$(base64 -w0 internal-key.pem)"
To disable TLS remove the relation:
juju remove-relation kafka-k8s <tls-certificates>
juju remove-relation zookeeper-k8s <tls-certificates>
