GitHub runner
| latest/stable | 707 | 16 Sep 2026 | |
| latest/stable | 4 | 02 Jun 2026 | |
| latest/stable | 327 | 02 Jun 2026 | |
| latest/stable | 696 | 02 Jun 2026 | |
| latest/beta | 697 | 30 Jun 2026 | |
| latest/edge | 708 | 12 Sep 2026 | |
| latest/edge | 707 | 12 Sep 2026 | |
COS integration
Metrics
Runner and charm insights
Upon COS integration, this charm initiates the transmission of various metrics—refer to the relevant specification for comprehensive details—regarding the runner instances and the charm itself.
There are two dashboards. One for fine-granular metrics, called “GitHub Self-Hosted Runner Metrics”, and one for long-term metrics, called “GitHub Self-Hosted Runner Metrics (Long-Term)”.
The “GitHub Self-Hosted Runner Metrics” metrics dashboard presents the following rows:
- General: Displays general metrics about the charm and runners, such as:
- Share of jobs per application: A pie chart showing the share of jobs per application.
- Lifecycle counters: Tracks the frequency of Runner initialisation, start, stop, and crash events.
- Available runners: A horizontal bar graph showing the number of runners available (and max expected) during the last reconciliation event. Note: This data is updated after each reconciliation event and is not real-time.
- Runners after reconciliation: A time series graph showing the number of runners marked as active/idle, the number of expected runners, and the difference between expected and the former (unknown) during the last reconciliation event over time. Note: This data is updated after each reconciliation event and is not real-time.
- Duration observations: Each data point aggregates the last hour and shows the 50th, 90th, 95th percentile and maximum durations for:
- Runner installation
- Runner idle duration
- Charm reconciliation duration
- Job queue duration - how long a job waits in the queue before a runner picks it up
- Max job queue duration by application: Similar to “Job queue duration” panel, but shows maximum durations by charm application.
- Average reconciliation interval: Shows the average time between reconciliation events, broken down by charm application.
- Jobs: Displays certain metrics about the jobs executed by the runners. These metrics can be displayed per repository by specifying a
regular expression on the
Repositoryvariable. The following metrics are displayed:- Proportion charts: Share of jobs by completion status, job conclusion, application, repository policy check failure http codes and GitHub events over time.
- Job duration observation
- Number of jobs per repository
The “GitHub Self-Hosted Runner Metrics (Long-Term)” metrics dashboard displays the following rows:
- General: Contains the following panels:
- Total Jobs
- Runners created per application: Shows the number of runners created per charm application.
- Total unique repositories
- Time series chart displaying the number of jobs per day
- Percentage of jobs with low queue time (less than 60 seconds)
Both dashboards allow for filtering by charm application by specifying a regular expression on the Application variable.
While the dashboard visualises a subset of potential metrics, these metrics are logged in a file named /var/log/github-runner-metrics.log. Use following Loki query to retrieve lines from this file:
{filename="/var/log/github-runner-metrics.log"}
These log events contain valuable details such as charm application, GitHub events triggering workflows along with their respective repositories, and more. Customising metric visualisation is possible to suit specific needs.
Machine host metrics
The grafana-agent autonomously transmits machine host metrics, which are visualised in the System Resources dashboard.
Logs
The grafana-agent effectively transmits all logs located at /var/log/**/*log, from the charm unit to Loki.
Relevant log files are (replace <app-name> with the name of the application and <unit-no> with the number of the unit)
/var/log/github-runner-manager/<app-name>-<unit-no>.log: It contains logs from the runner manager application. This is particularly useful for resolving issues related to reconciliation, such as problems with spawning VMs or contacting GitHub./var/log/juju/unit-<app-name>-<unit-no>.log: It contains the Juju debug logs. These are relevant for inspecting issues with the charm operating the runner manager application./var/log/reactive_runner/<reactive-process-pid>.log: It contains logs of the process of spawning a runner on demand. This is particularly relevant for troubleshooting issues , such as queue consumption issues or the inability to spawn VMs on OpenStack./var/log/github-runner-metrics.log: This contains the logs used to calculate metrics.
Use Loki to filter through multiple files or units.
Alerts
The charm contains a number of alerts that are sent to COS using the grafana-agent.
Please refer to the COS documentation for more information on how to set up alerts.
Alerts are divided into two categories:
- Capacity Alerts: Alerts you when there is a shortage of a particular type of runner.
- Failure Alerts: Notification of runner crashes or repository policy related failures.
