GitHub runner
24.04 22.04 20.04
latest/stable 697 30 Jun 2026
latest/stable 4 02 Jun 2026
latest/stable 327 02 Jun 2026
latest/stable 696 02 Jun 2026
latest/beta 697 30 Jun 2026
latest/beta 4 04 Jun 2025
latest/beta 323 17 Jan 2025
latest/edge 700 07 Jul 2026
latest/edge 699 07 Jul 2026
latest/edge 327 06 Feb 2025
latest/edge 4 26 Apr 2022
1/stable 177 05 Jun 2024
1/edge 177 05 Jun 2024
External access
The GitHub Runner Charm itself requires access to the
  • GitHub API (e.g. to register and remove runners).
  • GitHub website (e.g. to download the runner binary or other applications like yq)
  • Ubuntu package repositories (e.g. to install packages)
  • Snap store (e.g. to install LXD or aproxy)
  • Ubuntu Cloud Images (for the image used by a runner)
  • NPM registry (e.g. to download and install specific packages)
In addition, access is required depending on the requirements of the workloads that the runners will be running (as they will be running on the same machine as the charm).
More details on network configuration can be found in the charm architecture documentation.
Help improve this document in the forum (guidelines). Last updated 10 months ago.
