GitHub runner
| latest/stable | 697 | 30 Jun 2026 | |
| latest/stable | 4 | 02 Jun 2026 | |
| latest/stable | 327 | 02 Jun 2026 | |
| latest/stable | 696 | 02 Jun 2026 | |
| latest/beta | 697 | 30 Jun 2026 | |
| latest/edge | 700 | 07 Jul 2026 | |
| latest/edge | 699 | 07 Jul 2026 | |
How to debug with ssh
The charm exposes an integration debug-ssh interface which can be used with
tmate-ssh-server charm to pre-configure runners with
environment variables to be picked up by action-tmate
for automatic configuration.
Requirements
To enhance the security of self-hosted runners and its infrastructure, only authorized connections can be established. Hence, action-tmate users must have ssh-key registered on the GitHub account.
Deploying
Use the following command to deploy and integrate github-runner with tmate-ssh-server.
juju deploy tmate-ssh-server
juju integrate tmate-ssh-server github-runner
Idle runners will be flushed and restarted. Busy runners will be configured automatically on next spawn.
Using the action
Create a workflow that looks like the following within your workflow to enable action-tmate.
name: SSH Debug workflow example
on: [pull_request]
jobs:
build:
runs-on: [self-hosted]
steps:
- uses: actions/checkout@v3
- name: Setup tmate session
uses: canonical/action-tmate@main
The output of the action looks like the following.
<workflow setup logs redacted>
SSH: ssh -p 10022 <user>@<ip>
or: ssh -i <path-to-private-SSH-key> -p10022 <user>@<ip>
Read more about action-tmate’s usage here.
