GitHub runner
22.04
20.04
| latest/stable | 697 | 30 Jun 2026 | |
| latest/stable | 4 | 02 Jun 2026 | |
| latest/stable | 327 | 02 Jun 2026 | |
| latest/stable | 696 | 02 Jun 2026 | |
| latest/beta | 697 | 30 Jun 2026 | |
| latest/edge | 700 | 07 Jul 2026 | |
| latest/edge | 699 | 07 Jul 2026 | |
Integrations
This document provides an overview of the integrations supported by the GitHub Runner charm.
debug-ssh
Interface: debug-ssh
Supported charms: tmate-ssh-server
Debug-ssh integration provides necessary information for runners to provide ssh reverse-proxy applications to setup inside the runner.
Example debug-ssh integrate command:
juju integrate github-runner tmate-ssh-server
mongodb
Interface: mongodb_client
Supported charms: mongodb, mongodb-k8s
The mongodb integration provides the necessary information for the runner manager to access the mongodb database, which is required for the (experimental) reactive spawning feature. Integrating the charm with mongodb lets the charm automatically go into reactive mode.
Example mongodb_client integrate command:
juju integrate github-runner mongodb
