GitHub runner
24.04 22.04 20.04
latest/stable 697 30 Jun 2026
latest/stable 4 02 Jun 2026
latest/stable 327 02 Jun 2026
latest/stable 696 02 Jun 2026
latest/beta 697 30 Jun 2026
latest/beta 4 04 Jun 2025
latest/beta 323 17 Jan 2025
latest/edge 700 07 Jul 2026
latest/edge 699 07 Jul 2026
latest/edge 327 06 Feb 2025
latest/edge 4 26 Apr 2022
1/stable 177 05 Jun 2024
1/edge 177 05 Jun 2024
How to deploy on ARM64
The charm supports deployment on ARM64 machines. However, it should be noted that the ARM64 deployment currently only supports ARM64 bare-metal machines due to the limitations of nested virtualization on ARM64.
The following uses AWS’s m7g.metal instance to deploy the GitHub Runner on ARM64 architecture.
Requirements
  1. Juju with ARM64 bare metal instance availability.
    • On AWS: juju bootstrap aws <desired-controller-name>
  2. GitHub Personal Access Token
  3. Repository to register the GitHub runners.
Deployment steps
Run the following command:
juju deploy github-runner --channel=local-lxd/stable \
    --constraints="instance-type=a1.metal arch=arm64" \
    --config token=<PERSONAL-ACCESS-TOKEN> --config path=<OWNER/REPO>
The units may take several minutes to settle. Furthermore, due to charm restart (kernel update), the Unit may become lost for a few minutes. This is an expected behavior and the unit should automatically re-register itself onto the Juju controller after a successful reboot.
Go to the repository > Settings (tab) > Actions (left menu dropdown) > Runners and verify that the runner has successfully registered and is online.
Help improve this document in the forum (guidelines). Last updated 1 year, 3 months ago.
