GitHub runner
| latest/stable | 707 | 16 Sep 2026 | |
| latest/stable | 4 | 02 Jun 2026 | |
| latest/stable | 327 | 02 Jun 2026 | |
| latest/stable | 696 | 02 Jun 2026 | |
| latest/beta | 697 | 30 Jun 2026 | |
| latest/edge | 708 | 12 Sep 2026 | |
| latest/edge | 707 | 12 Sep 2026 | |
Token scopes
In order to use the GitHub runner charm, a personal access token with the necessary permissions is required.
Fine grained access token scopes
Note: In addition to having a token with the necessary permissions, the user who owns the token also must have admin access to the organization or repository.
Organizational runners
The following are the permissions scopes required for the GitHub runners when registering as an organizational runner.
Organization:
- Self-hosted runners: read & write
Repository:
- Actions: read (required if COS integration is enabled and private repositories exist)
- Administration: read
- Contents: read (not required if the charm is configured to use OpenStack runners)
- Pull requests: read (not required if the charm is configured to use OpenStack runners)
Repository runners
The following are the permissions scopes required for the GitHub runners when registering as an repository runner.
- Actions: read (required if COS integration is enabled and the repository is private)
- Administration: read & write
- Metadata: read
Personal access token scopes
Depending on whether the charm is used for GitHub organizations or repositories, the following scopes should be selected when creating a personal access token.
To use this charm for GitHub organizations, the following scopes should be selected:
repoadmin:org
Repository runners
To use this charm for GitHub repositories, the following scopes should be selected:
repo
