GitHub runner
22.04
20.04
| latest/stable | 707 | 16 Sep 2026 | |
| latest/stable | 4 | 02 Jun 2026 | |
| latest/stable | 327 | 02 Jun 2026 | |
| latest/stable | 696 | 02 Jun 2026 | |
| latest/beta | 697 | 30 Jun 2026 | |
| latest/edge | 708 | 12 Sep 2026 | |
| latest/edge | 707 | 12 Sep 2026 | |
How to run on LXD cloud
This machine charm needs to run on virtual machines with nested virtualization enabled.
By default, Juju machines on LXD are containers.
To run this charm on LXD, add virt-type=virtual-machine to the constraints during deployment:
juju deploy github-runner --channel=local-lxd/stable --constraints="cores=2 mem=16G virt-type=virtual-machine" \
--config token=<TOKEN> --config path=<OWNER/REPO>
This constraint ensures the Juju machine hosting the charm is a LXD virtual machine. See
Managing resource usage for
recommendation on cores and mem constraint.
NOTE: The name of the application must not be longer than 29 characters. This is due to the nature of LXD pathing that must not exceed 108 bytes. 79 characters are reserved for path naming convention.
