GitHub runner
24.04 22.04 20.04
latest/stable 697 30 Jun 2026
latest/stable 4 02 Jun 2026
latest/stable 327 02 Jun 2026
latest/stable 696 02 Jun 2026
latest/beta 697 30 Jun 2026
latest/beta 4 04 Jun 2025
latest/beta 323 17 Jan 2025
latest/edge 704 01 Aug 2026
latest/edge 703 01 Aug 2026
latest/edge 327 06 Feb 2025
latest/edge 4 26 Apr 2022
1/stable 177 05 Jun 2024
1/edge 177 05 Jun 2024
How to set up reactive spawning
The charm provides an experimental feature to spawn runners reactively, depending on the jobs requested by GitHub. This feature is only available for runners on OpenStack cloud and is disabled by default and can be enabled by integrating the charm with a MongoDB charm.
Requirements
For the purposes of this how-to-guide, we assume that you have a machine model (named “machine-model”) that can be used to deploy runners on an OpenStack cloud and MongoDB, and a k8s model (named “k8s-model”) for the webhook router.
Steps
We are going to showcase the steps required to set up a reactive spawning environment with three runner flavors (large, large-arm, small) and a MongoDB database as a message queue.
Note, that the specific revisions/channels in the steps are only marked here for reproducibility, you should adapt the revisions/channels to your needs.
GitHub runner applications
For this how-to-guide, we decided to have deployed three GitHub Runner charm applications: large, large-arm, small . We need to deploy those with these names, to comply with the routing table defined below.
juju switch machine-model
juju deploy github-runner large --channel latest/stable ....
juju deploy github-runner large-arm --channel latest/stable ....
juju deploy github-runner small --channel latest/stable ....
Please refer to How to spawn OpenStack runner. for more information on how to deploy the runners.
MongoDB
You need to deploy a MongoDB application to use as a message queue. You can choose to use the machine charm or the k8s charm version, although we recommend using the machine charm as the k8s version may not be reachable from outside the k8s cluster.
juju deploy mongodb --channel 6/edge --revision 188
juju expose mongodb
juju offer mongodb:database
juju grant <user-in-k8s-cloud> consume <offer-name>
Integrate with the runner charms
juju integrate large mongodb
juju integrate large-arm mongodb
juju integrate small mongodb
Define a webhook in your organisation or repository where the self-hosted runners are registered
On your repository or organisation’s page on Github, you need to go to the settings and create a Webhook (e.g. https://github.com/canonical/github-runner-operator/settings/hooks). Please make sure to select
  • the Webhook URL to be the URL of the webhook router
  • the content type application/json
  • the secret you defined in the webhook router (if you have so, which is recommended for security reasons)
  • the individual event “Workflow jobs” (and only this, as all other events will just be rejected by the webhook router)
Webhook router
The webhook router is a k8s charm, therefore you need to deploy it on a k8s model.
First, define a routing table to decide which labels should be routed to which GitHub Runner charm application:
cat <<EOF > routing_table.yaml
- large: [large, x64]
- large-arm: [large, arm64]
- small: [small]
EOF
We decide to route all jobs with any label combination in the set large,x64 to the large application, large,arm64 to large-arm, and labels with small to small. This means, depending on which labels your users are setting in the workflow file, a VM of a different runner application will be used to execute the job.
Switch to the k8s model and deploy the webhook router charm:
juju switch k8s-model
juju deploy github-runner-webhook-router --channel latest/edge --revision 30 --config flavours=@routing_table.yaml --config default-flavour=small --config webhook-secret=<your-secret>
juju consume <offer-url>
juju integrate github-runner-webhook-router mongodb
[!IMPORTANT] The webhook router needs to be deployed with the name github-runner-webhook-router, as the database name is currently hardcoded in the charm.
In this example we use “small” as the default runner application, to which all jobs with empty labels (or default labels such as self-hosted,linux) are routed to.
In order to be reachable from GitHub, you need to make the webhook publicly available, you will need an ingress or the traefik charm to expose the webhook router:
juju deploy nginx-ingress-integrator --channel latest/edge --revision 117 --config path-routes='/' --config service-hostname='githubu-runner-webhook-router.my.domain' --config trust=True
juju integrate nginx-ingress-integrator github-runner-webhook-router
COS integration
You will probably also need some observability. The GitHub Runner and MongoDB machine charm provide COS integration via the cos-agent endpoint, and the Github Runner Webhook Router charm provides the usual endpoints (logging, metrics-endpoint, grafana-dashboard). Please refer to How to integrate with COS and Canonical Observability Stack (COS) documentation for more information.
Help improve this document in the forum (guidelines). Last updated 11 months ago.
