GitHub runner
22.04
20.04
| latest/stable | 707 | 16 Sep 2026 | |
| latest/stable | 4 | 02 Jun 2026 | |
| latest/stable | 327 | 02 Jun 2026 | |
| latest/stable | 696 | 02 Jun 2026 | |
| latest/beta | 697 | 30 Jun 2026 | |
| latest/edge | 708 | 12 Sep 2026 | |
| latest/edge | 707 | 12 Sep 2026 | |
How to change repository or organisation
This charm supports changing the GitHub repository or GitHub organisation the self-hosted runners are connected to.
By using juju config to change the charm configuration path to another repository or organisation, the charm unregisters and removes the old self-hosted runners and instantiates new ones for the new configuration.
juju config <APP_NAME> path=<PATH>
