WordPress
- By Canonical IS DevOps
latest/stable | 87 | 07 Mar 2024 | |
latest/edge | 95 | 26 Apr 2024 |
juju deploy wordpress-k8s --channel edge
How to retrieve initial credentials
Run the following command to get the initial admin password that can be used to login at
http://<wordpress-unit-ip>/wp-login.php
juju run-action wordpress-k8s/0 get-initial-password --wait
The output of the action should look something similar to the following:
unit-wordpress-k8s-0:
UnitId: wordpress-k8s/0
results:
password: <password> # password should look something like: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
status: completed
You can use the password to login to the admin account in http://<wordpress-unit-ip>/wp-admin.php
Note that if admin_password
value has been passed in the initial_settings
configuration, the
password from the action is invalid.
