WordPress
- By Canonical IS DevOps
latest/stable | 87 | 07 Mar 2024 | |
latest/edge | 95 | 26 Apr 2024 |
juju deploy wordpress-k8s --channel edge
How to configure object storage
Object storage configuration is required for wordpress-k8s charm to work with multi-unit deployments.
Follow the instructions on installing OpenStack from the OpenStack documentation. For testing purposes, you can install DevStack.
After successful installations, you should be able to see openrc
file at the location of
installation. Source openrc
and load the credentials by running
source openrc && printenv | grep OS_
You should be able to see
The contents of the command above should look something similar to the following.
export OS_CACERT=
export OS_PROJECT_NAME=demo
export OS_TENANT_NAME=demo
export OS_USERNAME=demo
export OS_PASSWORD=<strong-password>
export OS_REGION_NAME=RegionOne
export OS_IDENTITY_API_VERSION=3
export OS_AUTH_TYPE=password
export OS_AUTH_URL=http://<openstack-deployment-address>/identity
export OS_USER_DOMAIN_ID=default
export OS_PROJECT_DOMAIN_ID=default
export OS_VOLUME_API_VERSION=3
Configure openstack-objectstorage plugin
To configure Swift storage for wordpress-k8s, copy and paste the following yaml content and adjust the values accordingly.
auth-url: http://<openstack-deployment-address>/identity/v3
bucket: WordPress
copy-to-swift: 1
domain: Default
object-prefix: wp-content/uploads/
password: <strong-password>
region: RegionOne
remove-local-file: 0
serve-from-swift: 1
swift-url: swift_auth_url # obtain the value by running `swift auth`. The value should look
something like http://<openstack-deployment-address>:8080/v3/AUTH_1d449b4237d3499dabd95210c33ca150, exported under
OS_STORAGE_URL key.
tenant: demo
username: demo
You can then configure wordpress-k8s charm using the yaml contents above.
juju config wordpress-k8s wp_plugin_openstack-objectstorage_config="$(cat <path-to-yaml>)"
