WordPress
- By Canonical IS DevOps
latest/stable | 87 | 07 Mar 2024 | |
latest/edge | 95 | 26 Apr 2024 |
juju deploy wordpress-k8s --channel edge
How to contribute
Overview
This document explains the processes and practices recommended for contributing enhancements to the WordPress operator.
- Generally, before developing enhancements to this charm, you should consider opening an issue explaining your use case.
- If you would like to chat with us about your use-cases or proposed implementation, you can reach us at Canonical Mattermost public channel or Discourse.
- Familiarising yourself with the Charmed Operator Framework library will help you a lot when working on new features or bug fixes.
- All enhancements require review before being merged. Code review typically examines
- code quality
- test coverage
- user experience for Juju operators of this charm.
- Please help us out in ensuring easy to review branches by rebasing your pull request branch onto
the
main
branch. This also avoids merge commits and creates a linear Git commit history. - For further information on contributing, please refer to our Contributing Guide
Developing
Building from source
To build and deploy wordpress-k8s charm from source follow the steps below.
Docker image build
Build the wordpress.Dockerfile
image with the following command.
docker build -t wordpress -f wordpress.Dockerfile .
Microk8s upload docker artifacts
For microk8s to pick up the locally built image, you must export the image and import it within microk8s.
docker save wordpress > wordpress.tar
microk8s ctr image import wordpress.tar
Build the charm
Build the charm locally using charmcraft. It should output a .charm file.
charmcraft pack
Deploy WordPress
Deploy the locally built WordPress charm with the following command.
juju deploy ./wordpress-k8s_ubuntu-22.04-amd64_ubuntu-20.04-amd64.charm \
--resource wordpress-image=wordpress
You should now be able to see your local wordpress-k8s charm progress through the stages of the
deployment through juju status --watch 2s
Testing
The following commands can then be used to run the tests:
tox
: Runs all of the basic checks (lint
,unit
,static
, andcoverage-report
tox -e fmt
: Runs formatting usingblack
andisort
tox -e lint
: Runs a range of static code analysis to check the code. -
tox -e static
: Runs other checks such asbandit
for security issues. -
tox -e unit
: Runs the unit tests. -
tox -e integration
: Runs the integration tests. Integration tests require additional arguments depending on the test module.
Canonical contributor agreement
Canonical welcomes contributions to the WordPress Operator. Please check out our contributor agreement if you’re interested in contributing to the solution.
