WordPress
- By Canonical IS DevOps
latest/stable | 87 | 07 Mar 2024 | |
latest/edge | 95 | 26 Apr 2024 |
juju deploy wordpress-k8s --channel edge
How to enable WAF
This step will walk you through making your WordPress application secure using Modsecurity 3.0 Web Application Firewall.
Deploy and relate nginx-ingress-integrator charm.
juju deploy nginx-ingress-integrator
juju relate wordpress-k8s nginx-ingress-integrator
Enable Modsecurity 3.0 WAF*
*This feature is only available for nginx-ingress-integrator charm.
The modsecurity WAF is enabled by default.
By running kubectl describe wordpress-k8s-ingress
in the appropriate namespace, the result should
look something like the following:
Labels: app.juju.is/created-by=nginx-ingress-integrator
Namespace: wordpress-tutorial
Address:
Ingress Class: <none>
Default backend: <default>
Rules:
Host Path Backends
wordpress-k8s
/ wordpress-k8s-service:80
Annotations: nginx.ingress.kubernetes.io/enable-modsecurity: true
nginx.ingress.kubernetes.io/enable-owasp-modsecurity-crs: true
nginx.ingress.kubernetes.io/modsecurity-snippet:
SecRuleEngine On
SecAction "id:900130,phase:1,nolog,pass,t:none,setvar:tx.crs_exclusions_wordpress=1"
Include /etc/nginx/owasp-modsecurity-crs/nginx-modsecurity.conf
nginx.ingress.kubernetes.io/proxy-body-size: 20m
nginx.ingress.kubernetes.io/rewrite-target: /
nginx.ingress.kubernetes.io/ssl-redirect: false
Events: <none>
Note the nginx.ingress.kubernetes.io/enable-modsecurity: true
annotation.
