Charmed Spark K8s
  • Canonical | bundle
Channel Revision Published
latest/edge 4 06 Aug 2024
3.4/edge 4 06 Aug 2024
juju deploy spark-k8s-bundle --channel edge
Submitting Jobs using Spark Submit
Apache Spark comes with a command called spark-submit which can be used to submit Spark jobs to the cluster from scripts written in high-level languages like Python and Scala. For a quick example, let’s gather the statements that we ran in the Python shell earlier and put them together in a script:
from operator import add
from pyspark.sql import SparkSession
def count_vowels(text: str) -> int:
  count = 0
  for char in text:
    if char.lower() in "aeiou":
      count += 1
  return count
# Create a Spark session
spark = SparkSession\
        .builder\
        .appName("CountVowels")\
        .getOrCreate()
lines = """Canonical's Charmed Data Platform solution for Apache Spark runs Spark jobs on your Kubernetes cluster.
You can get started right away with MicroK8s - the mightiest tiny Kubernetes distro around!
The spark-client snap simplifies the setup process to run Spark jobs against your Kubernetes cluster.
Spark on Kubernetes is a complex environment with many moving parts.
Sometimes, small mistakes can take a lot of time to debug and figure out.
n = spark.sparkContext.parallelize(lines.splitlines(), 2).map(count_vowels).reduce(add)
print(f"The number of vowels in the string is {n}")
spark.stop()
We’ve added a few more lines to what we’ve executed so far. The Apache Spark session, which would be available by default in a PySpark shell, needs to be explicitly created. Also, we’ve added spark.stop at the end of the file to stop the Apache Spark session after completion of the job.
Let’s save the aforementioned script in a file named count_vowels.py. Once saved, let’s copy it to the S3 bucket because it needs to be accessible to pods in kubernetes.
In fact, when submitting the job, the driver won’t be running in the local machine but on a K8s pod, hence the script needs to be downloaded and then executed remotely in a dedicated pod. Copying the file to the S3 bucket can be done by the following command:
aws s3 cp count_vowels.py s3://spark-tutorial/count_vowels.py
# upload: ./count_vowels.py to s3://spark-tutorial/count_vowels.py
You can verify whether the file has been copied to the S3 bucket either using the MinIO Console UI or using the following command:
aws s3 ls spark-tutorial
# 2024-02-05 05:09:44        925 count_vowels.py
Now that the script has been uploaded to S3, we can run spark-submit and specify the path of the script in S3 as an argument.
spark-client.spark-submit \
    --username spark --namespace spark \
    --deploy-mode cluster \
    s3a://spark-tutorial/count_vowels.py
When you run the command, you’ll see log output in the console with information about the state of the pods executing the task. The state of the pods transitions from ContainerCreating to Running and then finally to Completed. The state of the pods can also be viewed using the kubectl command in a new shell.
watch -n1 "kubectl get pods -n spark"
You should see output similar to the following:
NAME                                      READY   STATUS      RESTARTS   AGE
count-vowels-py-f6af998d77ce02d0-driver   1/1     Running     0          17s
countvowels-2975f78d77ce2e6f-exec-2       1/1     Running     0          6s
countvowels-2975f78d77ce2e6f-exec-1       1/1     Running     0          6s
Among these pods, as explained before, we have a “driver” pod, that will be executing the script and orchestrating/coordinating the other two executor pods. If you observe closely the status of the pods while the job is being submitted, it’s the driver pod that gets created first. The driver pod spawns executor pods to execute the jobs. Once the job is completed, the driver and the executor pods are transitioned to the Completed state. We can see the job execution logs by viewing the pod logs of the driver pod.
To view the pod logs, we first need to identify the name of the driver pod. You can do that with kubectl and some text filtering as:
pod_name=$(kubectl get pods -n spark | grep "count-vowels-.*-driver" | tail -n 1 | cut -d' ' -f1)
echo $pod_name
Once we have identified the pod name, we can see the pod logs with kubectl logs command. To filter out just the output line from the logs, grep can be used together with kubectl logs.
# View entire pod logs
kubectl logs $pod_name -n spark
# View only the line containing the output
kubectl logs $pod_name -n spark | grep "The number of vowels in the string is"
# 2024-02-05T05:47:09.183Z [entrypoint] The number of vowels in the string is 128
Often times, the data files to be processed contain a huge amount of data, and it’s common to store them in S3 and then have jobs read data from there in order to process it. The example program that we have discussed earlier can be extended so that the text for our vowel character counting job is now fetched directly from a file in S3. For that, let’s download a sample file and then copy it to the S3 bucket as follows:
# Download a sample text file
wget "https://raw.githubusercontent.com/canonical/spark-client-snap/3.4/edge/README.md"
aws s3 cp README.md s3://spark-tutorial/README.md
Now, let’s modify the Python script count_words.py to process the lines read from the file in S3 instead.
  count = 0
  for char in text:
      count += 1
  return count
        .builder\
        .appName("SubmitExample")\
        .getOrCreate()
lines = spark.sparkContext.textFile("s3a://spark-tutorial/README.md")
n = lines.map(count_vowels).reduce(add)
spark.stop()
Now, let’s copy this script to S3 with the same command as before, and then run it with spark-submit
As before, you can get the results from pod logs with the following commands:
In this section, we learned how to submit jobs using spark-submit. In the next section, we’ll learn how to process streaming data in Charmed Apache Spark.
