Charmed Spark K8s
- Canonical | bundle
juju deploy spark-k8s-bundle --channel edge
Manage Service Accounts using the Python API
The spark-client snap relies on the spark8t toolkit. spark8t provides both a CLI and a programmatic interface to enhanced Apache Spark client functionalities.
Here we describe how to use the spark8t toolkit (as part of the spark-client snap) to manage service accounts using Python.
Preparation
The spark8t package is already part of the snap. However, if the python package is used outside of the snap context, please make sure that environment settings (described on the tool’s README) are correctly configured.
Furthermore, you need to make sure that PYTHONPATH contains the location where the spark8t libraries were installed within the snap (something like /snap/spark-client/current/lib/python3.10/site-packages)
Bind to Kubernetes
The following snipped allows you to import relevant environment variables into a confined object, among which there should an auto-inference of your kubeconfig file location.
import os
from spark8t.domain import Defaults
from spark8t.services import KubeInterface
# Defaults for spark-client
defaults = Defaults(dict(os.environ)) # General defaults
# Create a interface connection to k8s
kube_interface = KubeInterface(defaults.kube_config)
Note that if you want to override some of these settings, you can extend the Default class accordingly.
Alternatively, you can also use auto-inference using the kubectl command via
kube_interface = KubeInterface.autodetect(kubectl_cmd="kubectl")
Once bound to the k8s cluster, you have some properties of the connection readily available, e.g.
kube_interface.namespace
kube_interface.api_server
You can also issue some kubectl commands, using the exec method
service_accounts = kube_interface.exec("get sa -A")
service_accounts_namespace = kube_interface.exec(
"get sa", namespace=kube_interface.namespace
Manage Spark Service Accounts
All functionalities for managing Apache Spark service accounts are embedded within
the K8sServiceAccountRegistry that can be instantiated using the kube_interface
object we defined above
from spark8t.services import K8sServiceAccountRegistry
registry = K8sServiceAccountRegistry(kube_interface)
Once this object is instantiated we can perform several operations, as outlined in the sections below
Create new Apache Spark service accounts
New Apache Spark service accounts can be created by first creating a ServiceAccount
domain object, and optionally specifying extra-properties, e.g.
from spark8t.domain import PropertyFile, ServiceAccount
configurations = PropertyFile({"my-key": "my-value"})
service_account = ServiceAccount(
name="my-spark",
namespace="default",
api_server=kube_interface.api_server,
primary=False,
extra_confs=configurations,
The account can then be created using the registry
service_account_id = registry.create(service_account)
This returns an id, which is effectively the {namespace}:{username}, e.g. “default:my-spark”.
Listing spark service accounts
Once Apache Spark service accounts have been created, these can be listed via
spark_service_accounts = registry.all()
or retrieved using their ids
retrieved_account = registry.get(service_account_id)
Delete service account
The registry can also be used to delete existing service accounts
registry.delete(primary_account_id)
or using an already existing ServiceAccount object:
registry.delete(service_account.id)
Manage Primary Accounts
spark8t and spark-client snap have the notation of the so-called ‘primary’ service account, the
one that would be chosen by default if no specific account is provided. The
primary Apache Spark service account can be set up using:
registry.set_primary(service_account_id)
registry.set_primary(service_account.id)
The primary Apache Spark service account can be retrieved using
primary_account = registry.get_primary()
Manage configurations of Spark service accounts
Apache Spark service accounts can have a configuration that is provided (unless
overridden) during each execution of Spark jobs. This configuration is stored in the PropertyFile object, which can be provided on the creation of a ServiceAccount object (extra_confs argument).
The PropertyFile object can either be created from a dictionary, as
done above
static_property = PropertyFile({"my-key": "my-value"})
or also read from a file, e.g.:
static_property = PropertyFile.read(defaults.static_conf_file)
PropertyFile objects can be merged using the + operator:
merged_property = static_property + service_account.extra_confs
And ServiceAccount properties can be updated using new “merged” properties
via the API provided by the registry:
registry.set_configurations(service_account.id, merged_property)
Alternatively, you can also store these properties in files:
with open("my-file", "w") as fid:
merged_property.log().write(fid)
