Charmed Spark K8s
Channel Revision Published
latest/edge 4 06 Aug 2024
3.4/edge 4 06 Aug 2024
juju deploy spark-k8s-bundle --channel edge
How to run Apache Spark Streaming against Apache Kafka
The following guide is to set up Apache Spark for structured streaming with Apache Kafka.
As a pre-requisite, Juju has to be installed together with a kubernetes-based juju controller.
Setup
First, create a fresh Juju model to be used as a workspace for spark-streaming experiments:
juju add-model spark-streaming
Deploy the Apache ZooKeeper and the Apache Kafka k8s-charms. Single units should be enough.
juju deploy zookeeper-k8s --series=jammy --channel=edge
juju deploy kafka-k8s --series=jammy --channel=edge
juju integrate  kafka-k8s  zookeeper-k8s
Deploy a test producer application, to write messages to Charmed Apache Kafka:
juju deploy kafka-test-app --series=jammy --channel=edge --config role=producer --config topic_name=spark-streaming-store --config num_messages=1000
juju integrate kafka-test-app  kafka-k8s
To consume these messages we need to establish a connection between Apache Spark and Apache Kafka, which requires credentials.
We need to deploy the data-integrator charm, which performs credential retrieval:
juju deploy data-integrator --series=jammy --channel=edge --config extra-user-roles=consumer,admin --config topic-name=spark-streaming-store
juju integrate data-integrator kafka-k8s
juju run-action data-integrator/0 get-credentials --wait
We are using the service account set up in the previous examples.
We need to set up the environment in a Kubernetes pod launched in the same namespace as the Juju model (i.e. spark-streaming in this example).
The pod specification yaml goes as below:
apiVersion: v1
kind: Pod
metadata:
spec:
  containers:
  - image: ghcr.io/canonical/charmed-spark:3.4.1-22.04_stable
    ports:
    - containerPort: 18080
    command: ["sleep"]
    args: ["3600"]
Create the pod in the same namespace as the Juju model.
Launch a Bash shell inside the test pod.
kubectl apply -f ./testpod.yaml --namespace=spark-streaming
kubectl exec -it testpod -n spark-streaming -- /bin/bash
Create a Kubernetes cluster configuration within the test pod shell session to be able to work with spark-client.
Launch a pyspark shell to read the structured stream from Apache Kafka.
cd /home/spark
mkdir .kube
cat > .kube/config << EOF
<<KUBECONFIG CONTENTS>>
EOF
spark-client.service-account-registry create --username hello --namespace spark-streaming
spark-client.service-account-registry list
spark-client.pyspark --username hello --namespace spark-streaming --conf spark.executor.instances=1 --conf spark.jars.ivy=/tmp --packages org.apache.spark:spark-streaming-kafka-0-10_2.12:3.2.0,org.apache.spark:spark-sql-kafka-0-10_2.12:3.2.0
Within the pyspark shell, now use the credentials retrieved previously to read stream from Apache Kafka.
from pyspark.sql.functions import udf
from json import loads
username="relation-8"
password="iGvE6HrCru1vqEsUdgRTsZKlOLqbebMJ"
lines = spark.readStream \
          .format("kafka") \
          .option("kafka.bootstrap.servers", "kafka-k8s-0.kafka-k8s-endpoints:9092") \
          .option("kafka.sasl.mechanism", "SCRAM-SHA-512") \
          .option("kafka.security.protocol", "SASL_PLAINTEXT") \
          .option("kafka.sasl.jaas.config", f'org.apache.kafka.common.security.scram.ScramLoginModule required username={username} password={password};') \
          .option("subscribe", "spark-streaming-store") \
          .option("includeHeaders", "true") \
          .load()
get_origin = udf(lambda x: loads(x)["origin"])
count = lines.withColumn("origin", get_origin(col("value"))).select("origin")\
          .groupBy("origin", "partition")\
          .count()
count.awaitTermination()
