Prometheus Pushgateway Charmed Operator
| 1.11/stable | 33 | 07 Jul 2026 | |
| 1.11/candidate | 33 | 07 Jul 2026 | |
| 1.11/beta | 33 | 07 Jul 2026 | |
| 1.11/edge | 33 | 07 Jul 2026 | |
| dev/edge | 33 | 30 Jun 2026 | |
| 2/stable | 30 | 13 Nov 2025 | |
| 2/candidate | 32 | 18 Jun 2026 | |
| 2/beta | 32 | 18 Jun 2026 | |
| 2/edge | 32 | 17 Jun 2026 | |
| 1/stable | 27 | 14 May 2025 | |
| 1/candidate | 27 | 14 May 2025 | |
| 1/beta | 27 | 14 May 2025 | |
| 1/edge | 27 | 07 May 2025 |
juju deploy prometheus-pushgateway-k8s --channel 1/edge
Solution matrix
| K8s charm | Machine charm | Legacy charms - LMA deps | Non-juju workload | |
| Logs | LokiPushApiConsumer (for workloads that can communicate directly with Loki, LogProxyConsumer (installs promtail in the workload; not suitable for air-gapped), LogForwarder (pebble-native, Juju>=3.4.1) | cos_agent (subordinate, pulls logs from /var/log or from other snaps with a matching slot) |
| Metrics | prometheus_scrape (in-model), prometheus_remote_write (CMR) - with grafana-agent | cos_agent | cos-proxy | scrape-target, grafana-agent snap |
| Traces | tracing (instrumented workloads), charm_tracing (for the charm itself) | tracing (CMR), cos_agent | N/A | grafana-agent charm |
| Dashboards | grafana_dashboard, cos-configuration | cos_agent, cos-configuration | cos-proxy, cos-configuration | cos-configuration |
| Alert rules | via metrics and logs relations, cos-configuration | cos_agent, cos-configuration | cos-proxy, cos-configuration | cos-configuration |
