postgresql
Charmed PostgreSQL VM
latest/stable 345 09 Nov 2023
Ubuntu 22.04 Ubuntu 20.04 Ubuntu 18.04 Ubuntu 16.04 Ubuntu 14.04
latest/stable 239 09 Feb 2022
latest/stable 226 01 Apr 2021
14/stable 553 04 Feb 2025
14/stable 552 04 Feb 2025
14/candidate 553 28 Jan 2025
14/candidate 552 28 Jan 2025
14/beta 553 28 Jan 2025
14/beta 552 28 Jan 2025
14/edge 590 29 Mar 2025
14/edge 589 29 Mar 2025
16/beta 577 19 Mar 2025
Ubuntu 24.04
16/beta 578 19 Mar 2025
Ubuntu 24.04
16/edge 584 26 Mar 2025
Ubuntu 24.04
16/edge 583 26 Mar 2025
Ubuntu 24.04
juju deploy postgresql --channel 14/stable
24.04 22.04 20.04 18.04 16.04 14.04
System requirements
The following are the minimum software and hardware requirements to run Charmed PostgreSQL on VM.
Software
  • Ubuntu 22.04 (Jammy) or later.
Juju
The charm supports several Juju releases from 2.9 LTS onwards. The table below shows which minor versions of each major Juju release are supported by the stable Charmhub releases of PostgreSQL.
Juju major release Supported minor versions Compatible charm revisions Comment
3.6 LTS 3.6.1+ 552+ 3.6.0 is not recommended, while 3.6.1+ works excellent. Recommended for production!
3.5 3.5.1+ 363+ Known Juju issue in 3.5.0
3.4 3.4.3+ 363+ Know Juju issues with previous minor versions
3.3 3.3.0+ from 363 to 430 No known issues
3.2 3.2.0+ from 363 to 430 No known issues
3.1 3.1.7+ from 336 to 430 Juju secrets were stabilized in 3.1.7
2.9 LTS 2.9.49+ 288+
2.9.32+ from 288 to 430 No tests for older Juju versions.
Hardware
Make sure your machine meets the following requirements:
  • 8GB of RAM.
  • 2 CPU threads.
  • At least 20GB of available storage.
The charm is based on the charmed-postgresql snap. It currently supports:
  • amd64
  • arm64 (from revision 396+)
Contact us if you are interested in a new architecture!
Networking
  • Access to the internet is required for downloading required snaps and charms
  • Only IPv4 is supported at the moment
