Charmed PostgreSQL K8s
- Canonical
14/edge | 557 | Today | |
14/edge | 556 | Today | |
16/edge | 552 | 02 Apr 2025 |
How to enable COS Alert Rules
This guide will show how to set up Pushover to receive alert notifications from the COS Alert Manager with Awesome Alert Rules.
Charmed PostgreSQL VM ships a pre-configured and pre-enabled list of Awesome Alert Rules.
Screenshot of alert rules in the Grafana web interface
For information about accessing and managing COS Alert Rules, refer to the COS documentation.
- A deployed Charmed PostgreSQL K8s operator
- A deployed
cos-lite
bundle in a Kubernetes environment - Fully configured COS Monitoring
Enable COS alerts for Pushover
The following section is an example of the Pushover alerts aggregator.
The first step is to create a new account on Pushover (or use an existing one). The goal is to have the ‘user key’ and ‘token’ to authorize alerts for the Pushover application. Follow this straightforward Pushover guide.
Next, create a new COS Alert Manager config (replace user_key
and token
with yours):
cat > myalert.yaml << EOF
global:
resolve_timeout: 5m
http_config:
follow_redirects: true
enable_http2: true
route:
receiver: placeholder
group_by:
- juju_model_uuid
- juju_application
- juju_model
continue: false
group_wait: 30s
group_interval: 5m
repeat_interval: 1h
receivers:
- name: placeholder
pushover_configs:
- user_key: <relace_with_your_user_key>
token: <relace_with_your_token>
url: http://<relace_with_grafana_public_ip>/cos-grafana/alerting/list
title: "{{ range .Alerts }}{{ .Labels.severity }} - {{ if .Labels.juju_unit }}{{ .Labels.juju_unit }}{{ else }}{{ .Labels.juju_application }}{{ end }} in model {{ .Labels.juju_model }}: {{ .Labels.alertname }} {{ end }}"
message: "{{ range .Alerts }} Job: {{ .Labels.job }} Instance: {{ .Labels.instance }} {{ end }}"
templates: []
EOF
Upload and apply newly the created alert manager config:
juju switch <k8s_cos_controller>:<cos_model_name>
juju config alertmanager config_file=@myalert.yaml
At this stage, the COS Alert Manager will start sending alert notifications to Pushover. Users can receive them on all supported Pushover clients/apps.
The image below shows an example of the Pushover web client:
Alert receivers
The similar way as above, COS alerts can be send to the long list of supported receivers.
Do you have questions? Contact us!
