Charmed PostgreSQL K8s
- Canonical
14/edge | 555 | 04 Apr 2025 | |
14/edge | 554 | 04 Apr 2025 | |
16/edge | 552 | 02 Apr 2025 |
Cross-regional async replication
Cross-regional (or multi-server) asynchronous replication focuses on disaster recovery by distributing data across different servers.
- Juju
v.3.4.2+
- Make sure your machine(s) fulfill the system requirements
Substrate dependencies
The following table shows the source and target controller/model combinations that are currently supported:
AWS | GCP | Azure | |
AWS | |||
GCP | |||
Azure |
How-to guides
- How to set up clusters for cross-regional async replication
- How to integrate with a client application
- How to remove or recover a cluster
