Charmed PostgreSQL K8s
- Canonical
14/edge | 557 | 10 Apr 2025 | |
14/edge | 556 | 10 Apr 2025 | |
16/edge | 552 | 02 Apr 2025 |
Charm types “legacy” vs “modern”
There are two types of charms stored under the same charm name postgresql-k8s
- Reactive charm in the channel
latest/stable
(calledlegacy
) - Ops-based charm in the channel
14/stable
(calledmodern
The legacy charm provided endpoints db
and db-admin
(for the interface pgsql
). The modern charm provides old endpoints as well + new endpoint database
(for the interface postgresql_client
). Read more details about the available endpoints/interfaces.
Note: Please choose one endpoint to use. No need to relate all of them simultaneously!
The default track “latest” vs “14”
The default track has been switched from the latest
to 14
for both VM and K8s PostgreSQL charms. It is to ensure all new deployments use a modern codebase. We strongly advise against using the latest track due to its implicit nature. In doing so, a future charm upgrade may result in a PostgreSQL version incompatible with an integrated application. Track 14 guarantees PostgreSQL 14 deployment only. The track latest
will be closed after all applications migrated from Reactive to Ops-based charm.
How to migrate from “legacy” to “modern” charm
The “modern” charm provides temporary support for the legacy interfaces:
- quick try: relate the current application with new charm using endpoint
db
(set the channel to14/stable
). No extra changes necessary:
postgresql:
charm: postgresql-k8s
channel: 14/stable
trust: true
- proper migration: migrate the application to the new interface “postgresql_client”. The application will connect PostgreSQL using “data_interfaces” library from “data-platform-libs” via endpoint
database
Warning: NO in-place upgrades possible! Reactive charm cannot be upgraded to Operator-framework-based one. To move DB data, the second/modern DB application must be launched nearby and data should be copied from “legacy” application to the “modern” one. Canonical Data Platform team is preparing copy&paste guide right now. Please contact us if you need migration instructions.
Note: the trust
option must be enabled if Role Based Access Control (RBAC) is in use on your Kubernetes.
How to deploy old “legacy” postgresql charm
Deploy the charm using the channel latest/stable
postgresql:
channel: latest/stable
Note: remove Charm store prefix cs:
from the bundle. Otherwise the modern charm will be chosen by Juju (due to the default track pointing to 14/stable
and not latest/stable
). The common error message is: cannot deploy application "postgresql": unknown option "..."
Config options supported by modern charm
The legacy charm config options were not moved to the modern charm due to no need. The modern charm applies the best possible configuration automatically. Feel free to contact us about the DB tuning/config options.
Extensions supported by modern charm
The legacy charm provided plugins/extensions enabling through the relation (interface pgsql
). It is NOT supported by the modern charm (neither pgsql
nor postgresql_client
interfaces). Please enable the necessary extensions using appropriate plugin_*_enable
config option of the modern charm. After enabling the modern charm will provide plugins support for both pgsql
and postgresql_client
interfaces.
Please find the list of supported PostgreSQL Extensions by modern charm. Feel free to contact us with a list of required extensions.
Roles supported by modern charm
In the legacy charm, the user could request roles by setting the roles
field to a comma separated list of desired roles. It is NOT supported by the modern charm implementation of the legacy pgsql
interface. The same functionality is provided via the modern postgresql_client
using “extra-user-roles”. Please check how to migrate on the new interface.
Supported PostgreSQL versions by modern charm
At the moment, the modern charms support PostgreSQL 14 (based on Jammy/22.04 series) only. Please contact us if you need different versions/series.
Supported architectures: amd64, arm64, …
Currently, the charm supports architecture amd64
(all revisions) and arm64
(from revision 211+).
See the technical details in Supported architectures
How to report issues and contact authors
The “legacy charm” (from latest/stable
) is stored on Launchpad, here is the link to report all legacy charm issues.
The “modern charm” (from 14/stable
) is stored on GitHub, here is the link to report modern charm issues.
Do you have questions? Contact us!
