| 2/stable | 168 | 24 Sep 2024 | |
| 2/candidate | 168 | 24 Sep 2024 | |
| 2/beta | 168 | 24 Sep 2024 | |
| 2/edge | 307 | Yesterday | |
| 2/edge | 306 | Yesterday |
Charmed OpenSearch Tutorial > 3. Enable TLS encryption
Enable encryption with TLS
Transport Layer Security (TLS) is a protocol used to encrypt data exchanged between two applications. Essentially, it secures data transmitted over a network.
Typically, enabling TLS internally within a highly available database or between a highly available database and client/server applications requires a high level of expertise. This has all been encoded into Charmed OpenSearch so that configuring TLS requires minimal effort on your end.
TLS is enabled by integrating Charmed OpenSearch with the Self Signed Certificates Charm. This charm centralises TLS certificate management consistently and handles operations like providing, requesting, and renewing TLS certificates.
In this section, you will learn how to enable security in your OpenSearch deployment using TLS encryption.
Self-signed certificates are not recommended for a production environment.
Check this guide for an overview of the TLS certificates charms available.
Configure TLS
Before enabling TLS on Charmed OpenSearch we must first deploy the self-signed-certificates charm:
juju deploy self-signed-certificates --config ca-common-name="Tutorial CA"
Wait until self-signed-certificates is active. Use juju status --watch 1s to monitor the progress.
tutorial opensearch-demo localhost/localhost 3.5.3 unsupported 12:39:22Z
opensearch blocked 3 opensearch 2/stable 168 no Missing TLS relation with this cluster.
self-signed-certificates active 1 self-signed-certificates latest/stable 155 no
opensearch/0* blocked idle 0 10.95.38.94 Missing TLS relation with this cluster.
opensearch/1 blocked idle 1 10.95.38.139 Missing TLS relation with this cluster.
opensearch/2 blocked idle 2 10.95.38.212 Missing TLS relation with this cluster.
self-signed-certificates/0* active idle 3 10.95.38.54
0 started 10.95.38.94 juju-be3883-0 ubuntu@22.04 Running
1 started 10.95.38.139 juju-be3883-1 ubuntu@22.04 Running
2 started 10.95.38.212 juju-be3883-2 ubuntu@22.04 Running
3 started 10.95.38.54 juju-be3883-3 ubuntu@22.04 Running
Integrate with OpenSearch
To enable TLS on Charmed OpenSearch, you must integrate (also known as “relate”) the two applications. We will go over integrations in more detail in the next page of this tutorial.
To integrate self-signed-certificates with opensearch, run the following command:
juju integrate self-signed-certificates opensearch
The OpenSearch service will start. This might take some time. Once done, you can see the new integrations with juju status --relations.
tutorial opensearch-demo localhost/localhost 3.5.3 unsupported 12:41:22Z
opensearch active 3 opensearch 2/stable 168 no
opensearch/0* active idle 0 10.95.38.94 9200/tcp
opensearch/1 active idle 1 10.95.38.139 9200/tcp
opensearch/2 active idle 2 10.95.38.212 9200/tcp
opensearch:node-lock-fallback opensearch:node-lock-fallback node_lock_fallback peer
opensearch:opensearch-peers opensearch:opensearch-peers opensearch_peers peer
opensearch:upgrade-version-a opensearch:upgrade-version-a upgrade peer
self-signed-certificates:certificates opensearch:certificates tls-certificates regular
Notice the last relation: self-signed-certificates:certificates opensearch:certificates tls-certificates regular.
Next step: 4. Integrate with a client application
