opensearch
OpenSearch
2/stable 168 24 Sep 2024
2/candidate 168 24 Sep 2024
2/beta 168 24 Sep 2024
2/edge 307 Yesterday
Ubuntu 24.04 Ubuntu 22.04
2/edge 306 Yesterday
How to deploy on LXD
This guide summarizes how to set up your machine and deploy Charmed OpenSearch on LXD, Canonical’s lightweight container hypervisor.
If you are a beginner to OpenSearch or Juju and are looking for a more comprehensive walkthrough of these steps, refer instead to the Tutorial.
Juju v.3.5.3+: Install Juju, but do not bootstrap anything yet.
See also: How to install Juju
LXD v6.1+: Install and initialize LXD.
See also: FIrst steps with LXD
System requirements: Check that you fulfill the rest of the software and hardware requirements in the system requirements page.
Disable IPv6 on LXD
Juju does not support IPv6 addresses with LXD. To set the network bridge to have no IPv6 addresses, run the following command after initializing LXD:
lxc network set lxdbr0 ipv6.address none
See The LXD cloud and Juju for more information.
Sysctl configuration
Before bootstrapping Juju controllers, sysconfigs required by OpenSearch must be enforced. This entails modifying some kernel parameters on the host machine, and creating a configuration file to apply the same configuration in any new container that gets deployed.
The following instructions will modify your kernel parameters. You can later reset them either manually or by rebooting.
To take note of the original values, run
sudo sysctl -a | grep -E 'swappiness|max_map_count|tcp_retries2'
Configure sysctl on the host machine
On the host machine, add the settings below to a config file:
sudo tee /etc/sysctl.d/opensearch.conf <<EOF
vm.swappiness = 0
vm.max_map_count = 262144
net.ipv4.tcp_retries2 = 5
EOF
Then, apply the new settings:
sudo sysctl -p /etc/sysctl.d/opensearch.conf
Now you can bootstrap a Juju controller:
juju bootstrap localhost
Configure sysctl for new containers
Configure cloud-init to set sysctl on each new container that gets deployed.
First, add the configurations to a cloud-init user data file:
cat <<EOF > cloudinit-userdata.yaml
cloudinit-userdata: |
  postruncmd:
    - [ 'echo', 'vm.max_map_count=262144', '>>', '/etc/sysctl.conf' ]
    - [ 'echo', 'vm.swappiness=0', '>>', '/etc/sysctl.conf' ]
    - [ 'echo', 'net.ipv4.tcp_retries2=5', '>>', '/etc/sysctl.conf' ]
    - [ 'echo', 'fs.file-max=1048576', '>>', '/etc/sysctl.conf' ]
    - [ 'sysctl', '-p' ]
EOF
Now, there are two options to apply this cloud-init configuration: set as the default config to be used by every new model created after that, or set it as a config for a target model.
To set the cloud-init script above as default for all models, use the model-defaults command:
juju model-defaults --file=./cloudinit-userdata.yaml
To set the cloud-init script for a particular model, use the model-config command:
juju model-config --file=./cloudinit-userdata.yaml --model <model_name>
Deploy OpenSearch
Create a model if you haven’t already:
juju add-model <model_name>
In a single host deployment with LXD, we recommend using the testing profile, which will only consume 1G RAM per container.
To deploy OpenSearch with the testing profile, run
Help improve this document in the forum (guidelines). Last updated 3 months ago.
